How to fix CalDAV|CardDAV|WebDAV problems
If you encounter the following scenario:
  • You can access your owncloud web interface
  • The owncloud sync client as well as WebDAV (via some WebDAV client, or a direct access in a browser via http://yourowncloud/remote.php/webdav) aren’t working (typically you will see a 401/403/405 error in the logs)
  • You’re getting a message “Your web server is not yet properly setup to allow files synchronization because the WebDAV interface seems to be broken. Please double check the installation guides.”
There are few common reasons for such a problem:
  1. You are using an outdated version of the client (upgrade to the newest version, available here, and try again)
  2. Rewrite module is not enabled / not configured or not working properly
  3. On the server running owncloud, a separate WebDAV module is enabled, and it interferes with owncloud’s built-in WebDAV module.
  4. You could have some required HTTP verbs disabled
  5. Your webserver has configured a Basic Auth authentication
  6. Your webserver isn’t passing your credentials to php in the standard way (You will see a message like “Sabre_DAV_Exception_NotAuthenticated No basic authentication headers were found”). See below for more info.
  7. You have a security software/module (like SELinux) running
  8. One or more module listen in this FAQ is installed / enabled
  9. You might be running ownCloud behind a reverse proxy; in that case you should ensure that your proxy is configured to pass WebDAV queries. See this forum thread for the case of the Pound reverse proxy: ownCloud Central
  10. You are using php in cgi mode on CentOS.
“WebDAV interface seems to be broken” message
Basic infos about this problem could be found in the owncloud.log like described in this FAQ thread:
Lighttpd users
You need to update lighttpd to a version which supports the PATCH method (at least 1.4.32) or apply this patch to your old version:
See also the official documentation for some more infos:
Running a test suite against your WebDAV/CalDAV/CardDAV
With litmus it is possible to run some tests against the WebDAV URL of OC to test if your webserver is correctly configured. More infos can be found at the homepage of litmus:
http://www.webdav.org/neon/litmus/
http://sabre.io/dav/litmus/
There also several CalDAV/CardDAV test suites available:
http://trac.calendarserver.org/wiki/CalDAVTester
http://www.calconnect.org/ioptesting.shtml
To check the rewrite module (apache)
Make sure the rewrite module is enabled; as root, execute:
a2enmod rewrite
Make sure you have a line like this in your .htaccess:
RewriteEngine on
If you needed to change anything, restart your apache afterwards (“apache2ctl graceful”) - pay attention to any error messages you might receive during server startup!
If you have mod_fcgid running with apache
According to this commit:
you should make sure that the following apache modules are enabled:
mod_setenvif
mod_headers
when running mod_fcgid
To check for a WebDAV module:
If this is your own server, see this other FAQ entry about known problems with webserver modules.
If you have owncloud running on a hosting provider, check the provider’s configuration interface for your website on any WebDAV configuration options, and disable them, at least for the owncloud folder. If you don’t see any such option, you have to ask your hoster to do this for you.
To enable all HTTP verbs:
Workaround for the “No basic authentication headers were found” problem
Check these threads:
To fix problems with SELinux
Check e.g. this thread: ownCloud Central
Authentication fails / special characters
Make first sure that you’re using no special chars in your password which could cause authentication failures:
Debugging
If nothing of the above helps using a command line tool like cadaver (cadaver WebDAV client) like described here:
could also provide useful informations about what’s wrong with your WebDAV setup.
Webdav, caldav, Client - authorization
CardDav not syncing with SSL Proxy in use
iPhone 6s iOS 10.0.2 Calendar won't sync
File synchronization problems
Problem with Lightning calendar synchronizing
Can not connect with any client
PROPFIND 405 Method Not Allowed on route remote.php/webdav
Backup and Restore OC -> Webdav auth failure
Kalender-Sync (caldav) funktioniert nur vom Server zum PC bzw. Smartphone, aber nicht zurück zum Server
Empty admin area
Server did not acknowledge the last chunk. (No e-tag were present)
"This operation is forbidden" after fresh install
Owncloud 9.1.1-1.2 / MacOS Sierra: CardDAV not working [solved]
Error deleting files
Use CURL to upload files to OC
Owncloud 9.1.1-1.2 and Davdroid (1.3.1-ose) CalDAV-CardDAV
Synchronisation vom Desktop Client funktioniert nicht mehr
I use the HTTPS CDN to accelerate
Can't sync my owncloud with Windows Desktop client
Help with Web Installer
Cannot connect to my ownCloud on server - Linux Mint
Remote.php/webdav not implemented
No Add (+) button on files page
First steps to Calendar sync
Can not connect by client or app to my server
CardDAV nginx problem
Calendar - cannot create or import calendars or events
Error transferring http://xxx.xxx.xxx.xxx/owncloud/remote.php/webdav - server replied: Not Acceptable
Connection error with Android
Desktop App Not Accepting App Passwords after 9.1 install
Unable to login from client or app
OWNCloud and CloudLinux
Windows client does not connect with server
Clients (Android & Win) can't connect
New to ownCloud - Fresh Install - Many Errors!
Another WebDav login Problem... Auth error 401
WebDav Error (400 Bad Request) PROPFIND
Trying to resolve "WebDAV interface seems to be broken" issue
Windows Desktop client cannot connect to server
Login from web page ok, login from clients failed
Windows fails to map via WedDAV - PROPFIND method error 405
"405 Not Allowed" when uploading, editing or removing files
