ENV:
oC: 10.0.10.4
Linux: x86_64-redhat
Apache: 2.4.37
PHP: 7.1.26 fpm
SQL: 10.3.12-MariaDB
config: https://gist.github.com/stkjj/171edcf1eb55324f9d8d74741c3e3e68#file-oc-config
Installation was migrated from Uberspace 6 to Uberspace 7 acc. to Migrating ownCloud from uberspace 6 to uberspace 7
Redis not running (as no php-redis module is yet available - acc. to uberspace support)
cron delivers erratic:
PHP Fatal error: Uncaught PDOException: SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction in [path to owncloud]/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php:105
Stack trace:
#0 [path to owncloud]/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php(105): PDOStatement->execute(NULL)
#1 [path to owncloud]/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(1006): Doctrine\DBAL\Driver\PDOStatement->execute()
#2 [path to owncloud]/lib/private/DB/Connection.php(207): Doctrine\DBAL\Connection->executeUpdate('UPDATE `oc_file...', Array, Array)
#3 [path to owncloud]/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php(208): OC\DB\Connection->executeUpdate('UPDATE `oc_file...', Array, Array)
#4 [path to owncloud]/lib/private/DB/QueryBuilder/QueryBuilder.php(141): Doctrin in /var/www/virtual/whoamu/stefankremer.cloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php on line 115
any idea how to tackle this?
best regards Stefan
