Migrating ownCloud from uberspace 6 to uberspace 7
Migration as featured in https://doc.owncloud.org/server/10.0/admin_manual/maintenance/migrating.html
  1. cleaninstall of oC on new server
  2. maintenance mode for old server
  3. export db/import db
  4. rsync data folder
  5. rsync config.php
    what’s missing in a.m. doc:
    adopt config.php: change db-credentials, change path-name to data-dir, log-dir, tmp-dir, disable redis, as not yet installed
    what also could be missing in a.m. doc:
    change db-entries showing to old paths ?
  6. set owncloud to maintenance
  7. change DNS-entry from old to new IP
Just get the owncloud up and running (at least show maintenance mode screen)
waiting, waiting, waiting, … 504 bad gateway/gateway timeout
But: as in 1. cleaninstall - no apps beside the included ones are really installed!
S3
no
no
### Client configuration
**Browser:**
any
**Operating system:**
macOS
### Logs
https://gist.github.com/stkjj/bac7177e3264a0b9c71ab5576394cfd8#file-owncloud-log```
#### Browser log
i think as well that this could be the problem here like currently discussed in Access to files not possible after upgrade - #10 by anon21401411.
Moin,
… which leads to Access to files not possible after upgrade and the therein mentioned link to https://doc.owncloud.com/server/10.0/admin_manual/maintenance/manually-moving-data-folders.html
Update the oc_accounts table
says:
UPDATE oc_accounts SET home='/mnt/data/files/super-admin' WHERE id=1;
this of course has to be done for every single user account, as all home-dirs are in the new data-dir
Next:
Update the oc_jobs table
says:
UPDATE oc_jobs SET argument = '/your/new/data/path' WHERE id = <id of the incorrect record>;
at least in my db the “/” are espcaped by " \ " so path should read \/your\/new\/data\/path
I’m sure there’s a need for updating both the migration page as the How to Move Data-Dir page in the admin manual :wink:. /cc @settermjd
Besides that: what would be the suggestion to get the migrated instance up and running?
best regards Stefan
Migration now succeded after editing db-entries and config.php.
Would be glad to read an updated migration doc with next release :wink:
thx for help @anon21401411
