I encountered a very strange bug this morning. Unfortunately, I am not able to reproduce it anymore. I will try to describe what happened the best I can. I would be curious to know if someone else got similar issues.
Ok so, basically, I run OwnCloud on a raspberry pi which is connected to my local network. Usually, I connect to it with SSH from my laptop (also connected to my local network). However, the raspberry can also be accessed from outside the local network (I just have to replace its local address with a domain name I bought and tied to it). So in a normal situation, I connect to it with an ssh command like this: ssh <username>@<domain-name>
I would expect this to still work after installing the desktop client.
Yesterday, I installed the desktop client and connected it to the server using the right domain name. It worked. Before going to sleep, I shutdown my laptop but also the raspberry.
This morning, I started my laptop and the raspberry. When I start the raspberry, OwnCloud is not started directly (I have to start it manually). So, of course, the desktop client says it’s “disconnected”. In order to start the OwnCloud server, I try to SSH into my server as usual: ssh <username>@<domain-name>
. I get a “Connection Refused” error.
However, if I use the raspberry local address, it works: ssh <username>@<local-ip-address>
I get the same kind of behavior from my mobile when connected to the WiFi: I can only SSH using the local IP address.
But, if I try to connect from outside my local network, it works.
If I shut down the desktop client (running on my laptop), then my usual SSH command (ssh <username>@<domain-name>
) works again from my laptop but also from my mobile (connected to WiFi). That’s why I think that the OwnCloud desktop client is causing the error.
To sum up: I cannot connect to my raspberry, from ANY of my devices connected to the local network, as long as the desktop client is running on my laptop. What could be the cause of that?
Finally, I managed to start the OwnCloud server using the SSH command with its local IP address. As a consequence, the desktop client went from “disconnected” to “connected”. And now, I don’t have this issue anymore (even if I shut down the server again).
I don’t think that you could reproduce my issue unfortunately since it is quite specific to my setup. I am not able to reproduce it myself anymore since I started the OwnCloud server. I tried my best to describe the different steps in the previous section. Don’t hesitate to ask me for more details.
Operating system: Raspbian GNU/Linux 9 (stretch)
I use docker-compose to setup the server:
version: '2.1'
volumes:
files:
driver: local
mysql:
driver: local
backup:
driver: local
redis:
driver: local
services:
server:
image: owncloud/server:latest
depends_on:
- db
- redis
environment:
- OWNCLOUD_DOMAIN=<my-domain-name>
- OWNCLOUD_DB_TYPE=mysql
- OWNCLOUD_DB_NAME=owncloud
- OWNCLOUD_DB_USERNAME=owncloud
- OWNCLOUD_DB_PASSWORD=owncloud
- OWNCLOUD_DB_HOST=db
- OWNCLOUD_ADMIN_USERNAME=admin
- OWNCLOUD_ADMIN_PASSWORD=admin
- OWNCLOUD_MYSQL_UTF8MB4=true
- OWNCLOUD_REDIS_ENABLED=true
- OWNCLOUD_REDIS_HOST=redis
- OWNCLOUD_LOG_TIMEZONE=Europe/Paris
- OWNCLOUD_LOG_FILE=/var/www/owncloud/log/owncloud.log
networks:
- web
- internal
labels:
- traefik.enable=true
- traefik.frontend.rule=Host:<my-domain-name>
- traefik.port=8080
- traefik.docker.network=web
healthcheck:
test: ["CMD", "/usr/bin/healthcheck"]
interval: 30s
timeout: 10s
retries: 5
volumes:
- files:/mnt/data
- /var/log/owncloud:/var/www/owncloud/log
db:
image: webhippie/mariadb:latest
environment:
- MARIADB_ROOT_PASSWORD=owncloud
- MARIADB_USERNAME=owncloud
- MARIADB_PASSWORD=owncloud
- MARIADB_DATABASE=owncloud
- MARIADB_MAX_ALLOWED_PACKET=128M
- MARIADB_INNODB_LOG_FILE_SIZE=64M
healthcheck:
interval: 30s
timeout: 10s
retries: 5
volumes:
- mysql:/var/lib/mysql
- backup:/var/lib/backup
networks:
- internal
redis:
image: webhippie/redis:latest
environment:
- REDIS_DATABASES=1
healthcheck:
interval: 30s
timeout: 10s
retries: 5
volumes:
- redis:/var/lib/redis
networks:
- internal
networks:
web:
external: true
internal:
OwnCloud version: 10.3.1 (stable)
I use Traefik on the raspberry to setup HTTPS with Let’s Encrypt.
Client version: 2.6.0 (build 1714)
Operating system: Ubuntu 18.04.3 LTS (Bionic Beaver)
Qt version used by client package (Linux only, see also Settings dialog): 5.12.5
I installed the client with APT.
Don’t hesitate to ask me for specific logs if needed.
