I’m getting loads of these errors in my logs and I’ve no idea what they mean.
None
N/A
N/A
Operating system: Ubuntu
Web server: Apache2
PHP version: 7
external storage
rmdir(/mnt/hgfs/ [FILE PATH] ): Directory not empty at /var/www/owncloud/lib/private/Files/Storage/Local.php#109
unlink(/mnt/hgfs/ [FILE PATH] ): Operation not permitted at /var/www/owncloud/lib/private/Files/Storage/Local.php#105
Integrity status for oC9+
paste the results here.
You probably have a permission issue in /mnt/hgfs that your webserver can’t delete anything there. If you delete files in your webinterface they are likely to come back because they weren’t deleted on the file system. Can you confirm that (after deletion, create an empty textfile to trigger a rescan of the folder and the deleted file should re-appear)?
Yes, this can be fixed. Read into the manual of “mount” or in the manual of the filesystem you’re using how to give the proper permission to the webserver user running ownCloud (mostly user www-data).
As this is nothing ownCloud specific you might also want to ask for support in a community dedicated to your used linux distro.
As already written previously this is nothing ownCloud specific. So “mount” is nothing what you need to look up in the ownCloud manual.
To sum up:
Your external storage / mountpoint needs to be read and writeable by the webserver user running ownCloud. How to achieve this heavily depends on your environment so we can’t give you specific information about that.
Some hints for a search on your own on the net are:
Command man mount
linux permission mount
mount permissions
