sg72
July 16, 2020, 10:01am
#1
Hello
I have an ssd hard drive that is permanently plugged into my Mac OS 10,15,15 computer using usb.
All creations or modifications made on my SSD is automatically synchronized on my owncloud
Only I have a problem. I have backups of my old Mac OS versions on my ssd and owncloud can’t synchronize them! I have this message
I tried to delete my old versions but I got an “is locked” error
sorry for my English
sg72
July 16, 2020, 10:08am
#6
Sorry But I am not allowed to post images.
tom42
July 18, 2020, 11:43pm
#7
i did the following search: https://central.owncloud.org/search?q="file%20is%20locked" and found the following FAQ. Maybe this helps on how to unlock the file?
You can’t access files because they are locked and you find such errors in your logfile:
{"reqId":"0DijSqEkfOg2iyh9VD8J","remoteAddr":"xx.xx.xx.xx","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 423 \\\"path\\\/file.extension\\\" is locked\",\"Exception\":\"OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Exception\\\\FileLocked\",\"Code\":0,\"Trace\":\"#0
If you’re running the ownCloud 8.2.x branch make sure that you’re using at least 8.2.2 (previous versions had a bug causing this issue)…
sg72
August 4, 2020, 7:42am
#8
Hello tom42
Sorry but my english is not verry good.
Why when i try to store vacation movies in mpg format the transfer with owncloud crash and blocked?
Have you been able to unlock the files now?
How long did the upload take? Was it potentially longer than an hour?
Can you check your server configuration for this article:
https://doc.owncloud.com/server/admin_manual/configuration/files/big_file_upload_configuration.html
sg72
August 4, 2020, 9:58am
#10
My movie has a size 4,98 Go
sg72
August 7, 2020, 7:46am
#11
I transferred directly via ftp and it works
