I am synchronizing a local folder with a folder on the server. I have a subfolder “Debug_Build” which I want to exclude. I opened the dialog “Ignored files editor” and added “Debug_Build/”. The only effect is, that an empty local folder named “Debug_Build” is not created on the server. But as soon as files are created in this folder, everything is copied to the server. I also added “Debug_Build/*” to the exclusion list but it had no effect.
Is there any way to just exclude a subfolder?
I am using Version 5.2.1 (build 10807) under Windows.
Server version 8.2.10.2.
Yes, you do need to use “selective sync”. Just expand the little arrow next to your account in the UI.
Hi, @hodyroff, maybe this is not what the OP meant by “exclusion”.
As far as I know, “selective sync” is a feature that prevents undesired download. I guess the OP wants to prevent upload.
In this sense, the “Edit Ignored Files”/“Ignored Files Editor” feature (linked to sync-exclude.lst file) seems to be broken. Otherwise, which exact setting can be typed in to keep files from being undesirably uploaded?
In other words: is there a solution for this problem?
As soon as folder is exlcuded the de-selection works in both directions. Still a good question for the syntax …
Hi, @hodyroff, I’m glad to hear from the team
I am still stuck in the syntax problem, so if you discover anything new about it, it would be really welcome. I even created a dedicated question here on the Central.
Thanks in advance!
It is a pattern recognition, not a path recognition. The “/” does not work.
When you add “Debug” to the list, you will exclude all folders named like that and all files named like that … let us know how it works.
