External storage configuration don't works
  1. I’m trying setup external storage with S3
  2. I’m puting the correct information
  3. But just the red ligth shows
Debian 10
Apache 2.4
mysql Ver 15.1 Distrib 10.3.27-MariaDB
10.6.0
Fresh install
I am not aware that owncloud supports this.
EDIT: Because it’s an enterprise only feature. :grimacing:
Who knows, if you do not show us. :wink:
Please have a look at this : Using S3 as external storage does not work · Issue #35150 · owncloud/core · GitHub
Also this old thread How to configure Amazon S3 as External Storage?
It is solved. I just put the region information on the S3 configuration.
