Hey!
- folders (and its content) with special char ([ or ]) will not be synced
- Also folders with special chars ([ and ]) shall be synced
- create folder (with any content) with special char at the beginning on your desktop; e.g.: [2019] Halleluja
- let folder sync to server
- mark as offline with your android app
Can this problem be reproduced with the official owncloud server?
(url: https://demo.owncloud.org, user: test, password: test)
yes
Environment data
Android version: 9 and 5
Device model:  Motorola G6 and Telekom Puls (tablet)
Stock or customized system: stock
ownCloud app version: 2.10.1
ownCloud server version:10.2
no sufficient entry
not found
              @der-domi sounds like https://github.com/owncloud/android/issues/2481 . It got fixed and will be released in the 2.11. You can verify with the 2.11 beta ( see post ownCloud 2.11 beta app for Android )
if the same can be reproduced on the demo instance then personally i would report such an issue to a bugtracker rather then to a user support forums. From what i know bugs in the android app could be reported at GitHub · Where software is built
But maybe the following in the upcoming release 2.11 of the android client might be related?
Fix folder with brackets  does not show the content
You are right! Next time I will do that. I also had this idea after I write the question. But than I already received Michaels answer.
Thanks to you both. I will test it asap. But I also think that the above mentioned issue will fix the bug.
