Operating system:Centos
Web server:apache
Database:mysql
PHP version:5.6
ownCloud version (see ownCloud admin page):9.1.3
Updated from an older ownCloud or fresh install:fresh
I’m stuck with a task that seem basic. I need to create for a special temporary need 380 local accounts on an Owncloud 9.1 server.
This account are all in a accounts.txt file with a ; separator like this
My account 1;login1;password1
My account 2;login2;password2
Very simple, the first field is the display name, the second the uid/login, the third the password.
I follow instruction here ownCloud Documentation Overview
But my shell script does not work, I’ve always an error
First try with a shell script like this:
#! /bin/bash
while IFS=";" read display user pass
do
export OC_PASS=$pass
#echo -e "$display :\n\
# UID :\t $user\n\
# password :\t $pass\n\n"
**sudo -u apache php /var/www/html/owncloud/occ user:add --password-from-env --display-name="$display" --group="OWNCLOUD AG EXT" $user**
done < /root/accounts.txt
The result is
–password-from-env given, but OC_PASS is empty!
If I just display the fields (see the commented line), it’s working.
So I tried the following according to the documentation (su -s)
#! /bin/bash
do
# UID :\t $user\n\
**su -s /bin/sh apache -c "php /var/www/html/owncloud/occ user:add --password-from-env --display-name="$display" --group="OWNCLOUD AG EXT" $user"**
In this case, I have
RuntimeException]
Not enough arguments (missing: “uid”).
If someone have already created a script like this, you are welcome. In both case, it seems to be a variable not set but I don’t know how to keep them. May be it’s just a stupid thing I miss…
Thanks.
Christian.
