How to upgrade OC from 8.2.7 to next versions
HI,
I’m using OC 8.2.7 on a ubuntu server i would like to upgrade the OC from 8.2.7 to 9.0.x version. Can any one let me know how to move to versions.
Need which version are available also.
Thanks,
Walter
See [1] for some notes on how to upgrade. In your case you would need the following upgrade steps:
8.2.7 → latest 8.2.x → latest 9.0.x (and maybe → latest 9.1.x)
[1] Two servers, different OC versions - #4 by anon81984126
Thanks for the info and in 8.2.7 the admin page giving errors like the
This server has no working Internet connection. This means that some of the features like mounting external storage, notifications about updates or installation of third-party apps will not work. Accessing files remotely and sending of notification emails might not work, either. We suggest to enable Internet connection for this server if you want to have all features.
Thanks,
Walter
Please don’t mix different issues like the question about the update with this new issue.
The message itself is nothing what you need to care when doing the manual update/upgrade.
