- I make upgrade 8.2.7.1 → 8.2.11. OK.
- I make upgrade 8.2.11 → 10.10. OK.
- I follow steps from guide:
Manual ownCloud Upgrade :: Documentation for ownCloud (A Kiteworks Company)
ownCloud is working fine on version 10.10.
Contacts of users should be available.
Calendar of users should be available.
Calendar is missing.
Contacts are missing.
I copy manually directory apps/calendar from the old to the new instance.
The same for apps/contacts.
Contacts and canlendar do not appear in the new instalance.
How to copy data from contacts and calendar to the new instance?
Thank you.
Operating system: Linux Debian 10.12
Web server: Apache web server
Database: MariaDB
PHP version: 7.3
ownCloud version: 10.10
updated from 8.2.7.1
updated from 8.2.11
