Hello, so I started this question on the github repo and been told to post here instead. TLDR: I want to include my owncloud instance in another website through iframe but it appears to be blocked by the lack of Access-Control-Allow-Origin
According to @DeepDiver1975 It’s the CSP setup that disallow it but I don’t see the frame-ancestors parameter that would block an iframe from loading owncloud. And the browser itself say it refused to dispaly because ‘X-Frame-Options’ is set to ‘sameorigin’.
- configure owncloud to have “cors.allowed-domains”: “https:// example. com”
- configure a page to include an iframe with src=“owncloud. example. com/s/zhdavdjaz”
- load the page
the return header should include Access-Control-Allow-Origin: https:// example. com
without the header the browser refuse to load the content
If I understand correctly from this https:// www. moesif. com/blog/technical/cors/Authoritative-Guide-to-CORS-Cross-Origin-Resource-Sharing-for-REST-APIs/# for a simple request the only thing missing is the header part. However it looks like https:// github. com/owncloud/core/blob/2de709ee929ff8ffd480019c82e09929134ad41d/lib/public/AppFramework/ApiController.php#L85 that owncloud only send this header for a preflighted request. Is there something that i’m missing in the owncloud configuration?
Linux
Apache
MariaDB
7.2.17-0ubuntu0.18.04.1
10.2.1.4
fresh
docker
no
no
no
chrome
windows 10
