Trying to add a local hard drive as external storage and get the red square.
- Format new 1tb hard drive, call it owncloud mount to /media/owncloud
- Create folder /media/owncloud/data, set permissions following this
- Enable local storage
Green circle indicating storage added and available
Red square
Ubuntu 16.04 LTS
Apache2
mysql 14.14
10.4.1
fresh install
no errors reported.
“config”: {
“files_external_allow_create_new_local”: true,
“updatechecker”: false,
“instanceid”: “oc5n4f4iu1pc”,
“trusted_domains”: [
“192.168.1.9”
“datadirectory”: “/var/www/owncloud/data”,
“overwrite.cli.url”: “http://192.168.1.9”,
“dbtype”: “mysql”,
“version”: “10.4.1.3”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“mysql.utf8mb4”: true,
“logtimezone”: “UTC”,
“apps_paths”: [
“path”: “/var/www/owncloud/apps”,
“url”: “/apps”,
“writable”: false
“path”: “/var/www/owncloud/apps-external”,
“url”: “/apps-external”,
“writable”: true
“installed”: true
Enabled:
- comments: 0.3.0
- configreport: 0.2.0
- dav: 0.5.0
- federatedfilesharing: 0.5.0
- federation: 0.1.0
- files: 1.5.2
- files_external: 0.7.1
- files_mediaviewer: 1.0.2
- files_sharing: 0.12.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- firstrunwizard: 1.2.0
- market: 0.5.0
- notifications: 0.5.0
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- updatenotification: 0.2.1
Disabled: - encryption
- external
- user_external
local (trying to, anyway)
no
no
firefox
ubuntu 16.04
