I’m facing a problem when adding a folder as an external local storage. The problem is the same as here and here where a red square and message pops up. The message is this one
An error occurred while adding the external storage, please check the logs or contact the administrator
and if click the red square
An error occurred while loading external mount point: Local
neither did this solution help (The same literal question was asked on this forum, but can’t find it)
- Create a folder, chown it to www-data (both user and group) (also tried www-data:root with the same result)
- Enable local mount in config.php
- Add it to external local storage in admin settings
The mount should be added
The mount is not added, rather, an error message is thrown
Operating system: Ubuntu 20.04
Database: webhippie/mariadb:latest-arm64
ownCloud version: owncloud/server:10.9.1-arm64v8 (docker image)
Updated from an older ownCloud or fresh install: Fresh (docker)
Where did you install ownCloud from: docker-compose from official docker hub
https://pastebin.com/XxNHJ5if
In paste
Are you using external storage, if yes which one: None, trying to use local
Are you using encryption: no
Are you using an external user-backend, if yes which one: None
Which one is this for a Docker installation?
{"reqId":"hCTfnD9sOBBGjMLN0dOG","level":0,"time":"2022-05-01T15:43:20+00:00","remoteAddr":"172.19.0.2","user":"admin","app":"OC\\User\\Session::validateToken","method":"GET","url":"\/apps\/files_external\/globalstorages\/4?testOnly=true","message":"token a9744a7b73e4f9305c7b135ebbdd622897960fe5f85c1dd3cf678fcbffe976f89c4f0f94ae6f0311401cd825a396f90e74ec1858ca7f50eb4412d2390fe1a52f with token id 2427 found, validating"}
{"reqId":"hCTfnD9sOBBGjMLN0dOG","level":3,"time":"2022-05-01T15:43:20+00:00","remoteAddr":"172.19.0.2","user":"admin","app":"PHP","method":"GET","url":"\/apps\/files_external\/globalstorages\/4?testOnly=true","message":"stat(): stat failed for REDACTED_FOLDER at \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Local.php#135"}
Nothing relevant
