So i’m trying to either add a folder, or extend one of the current folders (documents/movies/photos) to add 2TB of storage for owncloud. I used this as a reference, and built this:
When I go to add the local folder from the drop down, I get a Red Square instead of the green circle and that folder is not accessible. I’ve been up and down the web for this, and nobody seems to have a straight answer. The perms on that folder are r/w/x, and I assume the VirtualBox appliance is using ‘root’ to run the actual instance, because there are no other users on that box. from where i’m sitting it should be up and ready to go, but it isn’t. Does anyone have any experience with this?
- add a 2TB mount on RHEL
- adjust the config.php for the local storage option
- attempt to create a local storage folder
Local Storage should be available.
Red Square next to the storage option, and it’s unavailable
RHEL:
ownCloud Version = 10.2.1.4
The is the owncloud appliace for VirtualBox:
<?php
$CONFIG = array (
'apps_paths' =>
array (
0 =>
array (
'url' => '/apps',
'writable' => false,
1 =>
array (
'path' => '/var/www/owncloud/custom',
'url' => '/custom',
'writable' => true,
'trusted_domains' =>
array (
0 => 'localhost',
'datadirectory' => '/var/lib/univention-appcenter/apps/owncloud/data/files',
'dbtype' => 'mysql',
'dbhost' => '172.17.42.1',
'dbname' => 'owncloud',
'dbuser' => 'owncloud',
'dbpassword' =>
'dbtableprefix' => 'oc_',
'log_type' => 'owncloud',
'supportedDatabases' =>
array (
0 => 'sqlite',
1 => 'mysql',
2 => 'pgsql',
'files_external_allow_create_new_local' => 'true',
'upgrade.disable-web' => true,
'default_language' => 'en',
'overwrite.cli.url' => ,
'htaccess.RewriteBase' => '/owncloud',
'logfile' => '/var/lib/univention-appcenter/apps/owncloud/data/files/owncloud.log',
'loglevel' => '3',
'mysql.utf8mb4' => true,
'memcache.distributed' => '\\OC\\Memcache\\Redis',
'redis' =>
array (
'host' => 'redis',
'port' => '6379',
'passwordsalt' => '
'secret' =>
'version' => '10.2.1.4',
'logtimezone' => 'UTC',
'installed' => true,
'instanceid' =>
'ldapIgnoreNamingRules' => false,
'log_rotate_size' => 104857600,
'onlyoffice' => array ('verify_peer_off' => TRUE),
**local storage** .
**Are you using encryption:** no
**Are you using an external user-backend, if yes which one:** no.
chrome:
windows 10
{"reqId":"QuI7BMRMusWQtrrdzfQN","level":3,"time":"2019-11-28T03:20:27+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"--","url":"--","message":"User backend OC\\User\\Database is returning home: \/var\/lib\/univention-appcenter\/apps\/owncloud\/data\/files\/owncloud for user: owncloud which differs from existing value: "}
{"reqId":"ZXzgkNOotpoWOUAsShx6","level":3,"time":"2019-11-28T03:21:04+00:00","remoteAddr":"","user":"--","app":"core","method":"--","url":"--","message":"Exception: {\"Exception\":\"OCP\\\\AppFramework\\\\QueryException\",\"Message\":\"Could not resolve OCA\\\\User_LDAP\\\\Jobs\\\\UpdateGroups! Class OCA\\\\User_LDAP\\\\Jobs\\\\UpdateGroups does not exist\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Utility\\\/SimpleContainer.php(110): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->resolve('OCA\\\\\\\\User_LDAP\\\\\\\\J...')\\n#1 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/ServerContainer.php(86): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->query('OCA\\\\\\\\User_LDAP\\\\\\\\J...')\\n#2 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/BackgroundJob\\\/JobList.php(253): OC\\\\ServerContainer->query('OCA\\\\\\\\User_LDAP\\\\\\\\J...')\\n#3 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/BackgroundJob\\\/JobList.php(209): OC\\\\BackgroundJob\\\\JobList->buildJob(Array)\\n#4 \\\/var\\\/www\\\/owncloud\\\/cron.php(114): OC\\\\BackgroundJob\\\\JobList->getNext()\\n#5 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Utility\\\/SimpleContainer.php\",\"Line\":96}"}
{"reqId":"lfrSP2y1fOSO3IdO66p0","level":3,"time":"2019-11-28T03:44:35+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"no app in context","method":"POST","url":"\/owncloud\/settings\/users\/users","message":"User backend OC\\User\\Database is returning home: \/var\/lib\/univention-appcenter\/apps\/owncloud\/data\/files\/tmarlette for user: tmarlette which differs from existing value: "}
{"reqId":"lfrSP2y1fOSO3IdO66p0","level":3,"time":"2019-11-28T03:44:35+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"settings","method":"POST","url":"\/owncloud\/settings\/users\/users","message":"Can't send new user mail to dyermakerii@gmail.com: Expected response code 220 but got an empty response"}
{"reqId":"Sc1TSMzEbqwpwOrjhZGf","level":3,"time":"2019-11-28T03:56:58+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"POST","url":"\/owncloud\/apps\/files_external\/globalstorages","message":"stat(): stat failed for \/data\/sda\/ at \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Local.php#135"}
{"reqId":"QJcB6tZjGYgXoAzhmqat","level":3,"time":"2019-11-28T03:57:10+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"PUT","url":"\/owncloud\/apps\/files_external\/globalstorages\/1","message":"stat(): stat failed for \/data\/sda-ownclloud\/ at \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Local.php#135"}
{"reqId":"LPliysW7kVO40EVBI4ZS","level":3,"time":"2019-11-28T03:57:12+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"PUT","url":"\/owncloud\/apps\/files_external\/globalstorages\/1","message":"stat(): stat failed for \/data\/sda-ownclloud\/ at \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Local.php#135"}
{"reqId":"wUYQllbmni5AXyDLQevZ","level":3,"time":"2019-11-28T03:57:14+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"PUT","url":"\/owncloud\/apps\/files_external\/globalstorages\/1","message":"stat(): stat failed for \/data\/sda-owncloud\/ at \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Local.php#135"}
{"reqId":"4IMYFxknAjvPuYWmjlHL","level":3,"time":"2019-11-28T03:57:29+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"stat(): stat failed for \/data\/sda-owncloud\/ at \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Local.php#135"}
{"reqId":"RxHyGHkgv95vmLqlemKd","level":3,"time":"2019-11-28T03:57:32+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/apps\/files_external\/globalstorages\/1?testOnly=true","message":"stat(): stat failed for \/data\/sda-owncloud\/ at \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Local.php#135"}
{"reqId":"jsgRZ7YxVNBc2b460ti9","level":3,"time":"2019-11-28T04:07:51+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"stat(): stat failed for \/data\/sda-owncloud\/ at \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Local.php#135"}
{"reqId":"KrouLtP7fIdzrRth64ea","level":3,"time":"2019-11-28T23:54:02+00:00","remoteAddr":"","user":"--","app":"core","method":"--","url":"--","message":"Exception: {\"Exception\":\"OCP\\\\AppFramework\\\\QueryException\",\"Message\":\"Could not resolve OCA\\\\User_LDAP\\\\Jobs\\\\UpdateGroups! Class OCA\\\\User_LDAP\\\\Jobs\\\\UpdateGroups does not exist\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Utility\\\/SimpleContainer.php(110): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->resolve('OCA\\\\\\\\User_LDAP\\\\\\\\J...')\\n#1 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/ServerContainer.php(86): OC\\\\AppFramework\\\\Utility\\\\SimpleContainer->query('OCA\\\\\\\\User_LDAP\\\\\\\\J...')\\n#2 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/BackgroundJob\\\/JobList.php(253): OC\\\\ServerContainer->query('OCA\\\\\\\\User_LDAP\\\\\\\\J...')\\n#3 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/BackgroundJob\\\/JobList.php(209): OC\\\\BackgroundJob\\\\JobList->buildJob(Array)\\n#4 \\\/var\\\/www\\\/owncloud\\\/cron.php(114): OC\\\\BackgroundJob\\\\JobList->getNext()\\n#5 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Utility\\\/SimpleContainer.php\",\"Line\":96}"}
{"reqId":"CFu6aE1s8aax1GoXLgkb","level":3,"time":"2019-11-28T23:57:08+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"stat(): stat failed for \/data\/sda-owncloud\/ at \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Local.php#135"}
{"reqId":"gjDmq3EBHshJlYBKJyTO","level":3,"time":"2019-11-28T23:57:31+00:00","remoteAddr":"172.17.42.1","user":"Administrator","app":"PHP","method":"GET","url":"\/owncloud\/apps\/files_external\/globalstorages\/1?testOnly=true","message":"stat(): stat failed for \/data\/sda-owncloud\/ at \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Local.php#135"}
