Marketplace is not able to connect for a fresh installed OwnCloud via QNAP
1.Version 10.0.10.1 (QNAP official Store) Latest(DOCKER COMPOSE)
2.Both version is not able to use the marketplace
No marketplace connection: cURL error 60: SSL certificate problem: certificate has expired
  1. From setting panel, the error message shows
This server has no working Internet connection. This means that some of the features like mounting external storage, notifications about updates or installation of third-party apps will not work. Accessing files remotely and sending of notification emails might not work, either. We suggest to enable Internet connection for this server if you want to have all features.
**Database: maria db
Hello Tongt,
why did you leave the template when you don’t fill it out?
How should anyone be able to help you if you just provide the error message and vaguely describe what you did?
In Order to help you please describe how you did the “latest compose” what’s in your yaml file, what’s in your .env file and what kind of server do you run for it.
Best Regards
Dmitry
Hi dmitry,
Sorry for that,
For QNAP apps, as a fresh install from qpkg qnap file, only mariadb connected. nothing configured.
I am using reverse proxy to get ssl for the whole system(traefik, so 443 and 80 ports is allocated for traefik)
For docker-compose:
version: ‘3.1’
services:
owncloud:
image: owncloud
restart: always
ports:
- 50222:80
volumes:
- /share/Container/owncloud/:/var/www/html
- /share/Container/owncloud/apps:/var/www/html/apps
- /share/Container/owncloud/config:/var/www/html/config
- /share/Container/owncloud/data:/var/www/html/data
network_mode: bridge
just these.
May I ask why you use docker-compose (which is a tool for running multiple containers who depend / communicate with other containers) if you just run ownCloud?
Could you run the compose file that is in our documentation as is and see if you still can’t connect to the marketplace?
Then you are pretty sure facing the Letsencrypt Root CA X3 Expiration issue, see No marketplace connection: cURL error 60
In the letsencrypt forum they write:
see Can't get QNAP to get LE SSL - Help - Let's Encrypt Community Support
