when i try to open MARKET i get this:
No marketplace connection: cURL error 60: SSL certificate problem: certificate has expired
The SSL certificate it’s right and will expire in 11 January 2022
That’s related to DST Root CA X3 Expiration (September 2021) - Let's Encrypt You have to update your OS packages.
Any chance of elaborating a bit?
I’m currently using Owncloud in a docker container
I’ve tried removing the certificate from both Ubuntu server and Owncloud container
and even allowed curl -k and still no go
I ran sudo -u www-data php occ market:upgrade market
and get market: No marketplace connection: cURL error 60: SSL certificate problem: certificate has expired
Any help what to do?
What’s your setup? You use the official Docker container from Docker Hub? What version? What’s your OS/version?
Currently using Ubuntu 20.04 with official docker container from Docker Hub and and has been updated over time to the latest version 10.8
Please post the output from curl -LI https://marketplace.owncloud.com executed on the host as well as from inside of the container.
****** Ubuntu *******
HTTP/2 200
accept-ranges: bytes
cache-control: max-age=0, no-store
content-language: en
content-security-policy: default-src ‘self’; img-src minio:9000 piwik./owncloud.com storage.marketplace./owncloud.com marketplace-storage.int./owncloud.com api.-adorable.io data: ‘self’;script-src s./ytimg.com www./youtube.com piwik./owncloud.com
https://www.-google.com/recaptcha/ https://www.-gstatic.com/recaptcha/ ‘self’ ‘unsafe-inline’ ‘unsafe-eval’ data:;style-src fonts.-googleapis.com cdn.-jsdelivr.net ‘unsafe-inline’ ‘self’;font-src fonts.-gstatic.com fonts.-googleapis.com cdn.-jsdelivr.net ‘self’; frame-src www.-youtube.com appcenter.-software-univention.de *.owncloud.com https://www.-google.com/recaptcha/
content-type: text/html
date: Thu, 18 Nov 2021 17:13:31 GMT
etag: “4ac-5b8c924081500”
last-modified: Wed, 13 Jan 2021 14:41:56 GMT
referrer-policy: strict-origin-when-cross-origin
server: Apache
strict-transport-security: max-age=315360000; preload
x-content-type-options: nosniff
x-frame-options: SAMEORIGIN
x-xss-protection: 1; mode=block
content-length: 1196
===Container on Ubuntu===
HTTP/2 200
content-security-policy: default-src ‘self’; img-src minio:9000 piwik.-owncloud.com storage.-marketplace.owncloud.com -marketplace-storage.int.owncloud.com -api.adorable.io data: ‘self’;script-src -s.ytimg.com -www.youtube.com -piwik.owncloud.com https://-www.google.com/recaptcha/ https://-www.gstatic.com/recaptcha/ ‘self’ ‘unsafe-inline’ ‘unsafe-eval’ data:;style-src -fonts.googleapis.com -cdn.jsdelivr.net ‘unsafe-inline’ ‘self’;font-src -fonts.gstatic.com -fonts.googleapis.com -cdn.jsdelivr.net ‘self’; frame-src -www.youtube.com -appcenter.software-univention.de *.owncloud.com https://www.-google.com/recaptcha/
date: Thu, 18 Nov 2021 17:14:09 GMT
server: Apache
Sorry for the bad links. Had to break them because I couldn’t “post a message with more than 2 links”
Hi @SaGal,
I don’t know whether this will work for your system, but here is what I’ve done to get the marketplace back.
After this, the curl error at marketplace was gone, the app is working as before.
You might give it a try.
Hmm, I really wonder why this is needed or fix the problem for some. We run several of oC 10.8 instances (Docker and host-based) on our own, and we have never seen this issue. If you are running an older version of oC, this could make the difference as the bundle may not include a new Let’s Encrypt ISRG Root X1 CA, but 10.8 should just work
Keep in mind that manually editing the resources/config/ca-bundle.crt file may cause integrity check issues.
I did a quick test and for the docker images, I’m still not able to reproduce it. Back to owncloud/server:10.0 the occ market command works without any issue for me.
It was working, until a few weeks before. Unfortunately, this was the one and only change that got the problem vanished. Of course, I know that this is just a workaround, but at least, I can continue to install and update my apps again. BTW, due to some patches, I have to deal with the integrity issue anyway.
Thank you very much!!
This indeed worked
