I just upgraded to the latest version (10.0.0.12) and I realized that, almost all my applications are vanished.
Documents, addressbook, tasks, calendar, ownnotes etc.
I tried to enable at least calendar/addressbook but I did not find them under the Disabled apps.
I also tried to start the Market app, which seems running, there is no error message, but I only got a Market/Categories small box on the page and there are no categories nor apps.
My question, is it my fault because I missed something or it is a bug or it is valid because there are no apps for 10.x yet?
Thank you!
István
as you can see on [1] there are already quite a lot apps published at the marketplace.
If you don’t get any of the marketplace apps showing up in your ownCloud installation then most likely the connection to https://marketplace.owncloud.com doesn’t work or similar. Your logfiles (PHP error log, data/owncloud.log, etc.) might tell you more.
I have the same problem as the OP. I upgraded from 9 to 10 and had to disable a few apps using occ app:disable because the updater failed when it couldn’t update them (gallery, PDF viewer).
Afterwards I wanted to reinstall them, but the “Apps” in the top left corner menu was gone. Instead, there is now “Market”. Opening the market however just results in a pretty empty page with a loading circle animation which endlessly spins.
The owncloud log shows a message when that happens: "url":"/index.php/apps/market/apps","message":"array_map(): Argument #2 should be an array at /var/www/owncloud/apps/market/lib/Controller/MarketController.php#221"
There’s also two errors in the developer console:
GET https://foobar/index.php/apps/market/has-license-key 404 (Not Found) in xhr.js?14ed:177
and
TypeError: Cannot read property 'length' of null in vue.runtime.esm.js?a427:519
at VueComponent.render (eval at (market.bundle.js?v=9cc73684cba861c61bac8fd54a19340a:1), :29:25)
at VueComponent.Vue._render (eval at (market.bundle.js?v=9cc73684cba861c61bac8fd54a19340a:1), :3899:22)
at VueComponent.updateComponent (eval at (market.bundle.js?v=9cc73684cba861c61bac8fd54a19340a:1), :2435:21)
at Watcher.get (eval at (market.bundle.js?v=9cc73684cba861c61bac8fd54a19340a:1), :2774:25)
at Watcher.run (eval at (market.bundle.js?v=9cc73684cba861c61bac8fd54a19340a:1), :2844:22)
at flushSchedulerQueue (eval at (market.bundle.js?v=9cc73684cba861c61bac8fd54a19340a:1), :2611:13)
at Array.eval (eval at (market.bundle.js?v=9cc73684cba861c61bac8fd54a19340a:1), :651:14)
at nextTickHandler (eval at (market.bundle.js?v=9cc73684cba861c61bac8fd54a19340a:1), :598:16)
at
Seeing this 404, I tried opening that URL in the browser, and the page said {"message":"No license key configured."} (and threw a 404).
I also see “Add API key” and “Start enterprise trial” buttons in the lefthand navigation of the market page. Does this mean I need an API key to be able to install apps from within the owncloud installation, even in the open source edition?
