After upgrading to owncloud 10.0.0 on an Ubuntu 14.04 server via standard apt I get no more updates. It seems like there have been at least two more updates including fixes to the calendar app that I would like to have. But for some reason they seem not to be available in Ubuntu 14.04.
Does anybody know if this is expected?
Does anybody know what I could do?
Can you show us your used repository, please?
I hope this is what you asked for:
cat /etc/apt/sources.list.d/owncloud.list
deb download.owncloud.com /
If you switch to:
you should get the newer 10.0 releases.
Thanks, that worked.
I thought that 10.0.2 was regarded as stable?
There have been an post about that a few weeks ago:
Hi all,
as some of you may have noticed, around the ownCloud 10.0.0 release there was a bit of confusion how "stable" the version is, especially the package installed versions. The reason for this is, that they are confusing the stable release channel with the production release channel. You can read our policy for release channels here: https://staging.owncloud.org/release-channels/
This post is only about the owncloud packages. For the sake of completeness: next to the owncloud packages, ā¦
xuhdev
March 6, 2018, 4:33am
7
Are you really sure? I visited the repo but found there is no package.
Hey there,
iām not sure but maybe you have missed that my quoted post is around 8 months old. Back then the mentioned packages where there.
