- enable LDAP
- Login as AD-User (User existed before ownCloud)
Default-files and folders should be there
all the menu-items are available but default-files/folders nor any upload-button
Operating system 1: Ubuntu 16.04 LTS (for ownCloud)
Operating system 2: Windows Server 2008R2x64 Standard (for Active Directory, DNS, DHCP, Storage)
Web server: Apache 2.4.8
Database: MySQL 5.7.16
PHP version: 7.0.12
ownCloud version: 9.1.1.3
Updated from an older ownCloud or fresh install: FRESH from *.tar.bz
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): LDAP, closed-network (lab on virtual-machines hosts)
ownCloud config
There’s nothing to hide, its simply a server for testing reasons ![]()
<?php
$CONFIG = array (
'instanceid' => 'oc90ei530bt6',
'passwordsalt' => 'zG/e7ZkS7o2pLaiMcifR8kULXsJKu8',
'secret' => 'L9SC61y8peox7nM0QAy0ldQcMyhsNC/4kINgtBbmCyDGAT8v',
'trusted_domains' =>
array (
0 => 'owncloud.test.ch',
'datadirectory' => '/var/www/html/owncloud/data',
'overwrite.cli.url' => 'https://owncloud.test.ch',
'dbtype' => 'mysql',
'version' => '9.1.1.3',
'dbname' => 'ocdb01',
'dbhost' => 'localhost',
'dbtableprefix' => 'oc_',
'dbuser' => 'oc_administrator',
'dbpassword' => 'RTt2FTup3/I5oOvtaBXyy3eKxaQX3E',
'logtimezone' => 'Europe/Zurich',
'installed' => true,
'memcache.local' => '\\OC\\Memcache\\Redis',
'memcache.distributed' => '\\OC\\Memcache\\Redis',
'filelocking.enabled' => 'true',
'redis' =>
array (
'host' => 'localhost',
'port' => 6379,
'timeout' => 0,
'dbindex' => 0,
'trashbin_retention_obligation' => 7,
'trashbin_auto_expire' => true,
'logdateformat' => 'F d, Y H:i:s',
'log_rotate_size' => 104857600,
'versions_retention_obligation' => '7,auto',
'ldapIgnoreNamingRules' => false,
'maintenance' => false,
'loglevel' => 0,
Debug user_ldap Requested attribute thumbnailphoto not found for cn=jeal,ou=users,ou=test,dc=test,dc=ch October 26, 2016 13:41:01
Debug user_ldap Ready for a paged search October 26, 2016 13:41:01
Debug user_ldap initializing paged search for Filter objectClass=* base Array ( [0] => cn=jeal,ou=users,ou=test,dc=test,dc=ch ) attr Array ( [0] => thumbnailPhoto ) limit 500 offset 0 October 26, 2016 13:41:01
Pasted possible errors:
APACHE 2
[Wed Oct 26 13:41:13.905712 2016] [authz_core:error] [pid 891] [client 192.168.1.20:49803] AH01630: client denied by server configuration: /var/www/html/owncloud/data/htaccesstest.txt, referer: https://owncloud.test.ch/index.php/settings/admin
Integrity status for oC9+
And this is how it looks like when AD-user logs in:
And
Personal-Settings look fine so far:
Also all (test) users are shown (ive used default-settings):
Any ideas where this error may belong to?
