ownCloud client "could not read system exclude file" error
Cattura
When I start ownCloud client
Client version: 2.5.3 and 2.6(master)
Operating system: Windows 10
I built ownCloud following the Windows Development Build with KDE Craft steps.
The sys-exclude.lst file is in the root folder.
Please check the debug-level log with this error:
https://doc.owncloud.org/desktop/2.5/troubleshooting.html#log-files
Thanks @michaelstingl. The location of sys-exclude.lst was wrong and I solved the issue moving it to the correct path.
Where is the right path could you tell?
