I have an ownCloud docker container behind traefik proxy.
The problem is that pictures in portrait perspective will be not turned in the gallery app. All the picutres does have the correct EXIF information and will be turned with e.g. IrfanView.
Does somebody know this issue and know what to do?
Thankes,
Dominik
- Make some pictures with your mobile phone in landscape and portrait perpestive in jpg format (e.g. IMG_20190504_235329629.jpg).
- upload to ownCloud with activated Gallery app
- navigate in Gallery to the uploaded picture
The portrait will be turned, so I don’t have to turn my head.
Also landscape pictures with turned phone shall be turned automatically.
The portrait will not be turned, so I have to turn my head.
For inverted landscape pictures I have to turn my head.
Operating system: Debian 9
Web server: Traefik proxy
Database: MariaDB 10
PHP version: Integrated into docker
ownCloud version: 10.1.1
Updated from an older ownCloud or fresh install: from docker 10.1
Signing status (ownCloud 9.0 and above): ?
Dockerfile (partially):
owncloud-test:
image: owncloud/server:10.1
container_name: owncloud-test
restart: always
depends_on:
- db
- redis
environment:
- OWNCLOUD_DOMAIN=xxx
- OWNCLOUD_DB_TYPE=mysql
- OWNCLOUD_DB_NAME=xxx
- OWNCLOUD_DB_USERNAME=xxx
- OWNCLOUD_DB_PASSWORD=xxx
- OWNCLOUD_DB_HOST=db
- OWNCLOUD_ADMIN_USERNAME=admin
- OWNCLOUD_ADMIN_PASSWORD=xxx
- OWNCLOUD_MYSQL_UTF8MB4=true
- OWNCLOUD_REDIS_ENABLED=true
- OWNCLOUD_REDIS_HOST=redis
volumes:
- ./owncloud-test-data:/mnt/data
labels:
- "traefik.backend=owncloud-test"
- "traefik.enable=true"
- "traefik.frontend.rule=Host:xxx"
- "traefik.port=8080"
- "traefik.docker.network=traefik_proxy"
- "traefik.frontend.headers.customResponseHeaders=Strict-Transport-Security:max-age=15552000"
networks:
- traefik_proxy
- default
Additional Info: I have checked the PHP-config via phpinfo(). Exif support is enabled.
EXIF Support
enabled
EXIF Version
7.2.15-0ubuntu0.18.04.2
Supported EXIF Version
0220
Supported filetypes
JPEG, TIFF
Multibyte decoding support using mbstring
enabled
"system": {
"apps_paths": [
"url": "\/apps",
"writable": false
"path": "\/var\/www\/owncloud\/custom",
"url": "\/custom",
"writable": true
"trusted_domains": [
"localhost"
"datadirectory": "\/mnt\/data\/files",
"dbtype": "mysql",
"dbhost": "db",
"dbname": "owncloudtest",
"dbtableprefix": "oc_",
"log_type": "owncloud",
"supportedDatabases": [
"sqlite",
"mysql",
"pgsql"
"upgrade.disable-web": true,
"default_language": "en",
"overwrite.cli.url": "http:\/\/xxx.de\/",
"htaccess.RewriteBase": "\/",
"logfile": "\/mnt\/data\/files\/owncloud.log",
"loglevel": 2,
"mysql.utf8mb4": true,
"filelocking.enabled": true,
"memcache.distributed": "\\OC\\Memcache\\Redis",
"redis": {
"host": "redis",
"port": "6379"
"version": "10.1.1.1",
"logtimezone": "UTC",
"installed": true,
"instanceid": "oc627z8ichyt",
"maintenance": false
Enabled:
- calendar: 1.6.2
- comments: 0.3.0
- configreport: 0.1.2
- contacts: 1.5.5
- dav: 0.4.0
- duo: 2.5.2
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.2
- files_external: 0.7.1
- files_sharing: 0.11.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.9
- firstrunwizard: 1.1.1
- gallery: 16.1.1
- market: 0.4.0
- notifications: 0.4.1
- oauth2: 0.4.0
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- twofactor_totp: 0.5.3
- updatenotification: 0.2.1
Disabled:
- encryption
- external
- twofactor_backup_codes
- user_external
- user_ldap
Are you using encryption: no
Browser: Firefox 66.0.5
Operating system: Windows 10
empty
