Owncloud does not work since PHP upgrade
  1. Open the Owncloud login URL
The Login Screen should appear
I get a lot of errors:
I can upload just 1 image and 2 links. I merged all files to this Gist.
All Logs here: https://gist.github.com/Gitulu/798f888c7ce3e77cdad888a3045de4f5
Operating system:Debian Linux 10
Web server: Apache Webserver
Database: It should be Mysql (not sure)
PHP version: installed: “5.6, 7.0, 7.1, 7.2 and 7.3” -> running: “7.0.33”
PHP Modules please see Gist above
PHP 7.0.33-10+0~20190807.18+debian9~1.gbp5452d8 (cli) (built: Aug 7 2019 19:47:15) ( NTS )
Copyright © 1997-2017 The PHP Group
Zend Engine v3.0.0, Copyright © 1998-2017 Zend Technologies
with Zend OPcache v7.0.33-10+0~20190807.18+debian9~1.gbp5452d8, Copyright © 1999-2017, by Zend Technologies
10.2.1 stable community
Where did you install ownCloud from: https://owncloud.org/download/
Please see Gist above
Both methods does not work to get the content
I have acces to the server and the terminal via Bitvise but the commands does not work
Internal server storage from the VPS
Are you using encryption: yes
How can I rescue my files I have the keys and login details?
Browser: Chrome, Firefox (newest version)
Operating system: Windows 10 - 1903 - 64Bit
Insert your webserver log here: Please see Gist above
Insert your ownCloud log here: Please see Gist above
Please let me know how I can assist you.
It would be great to to rescue my files or to fix the issues.
Thank you
Clabin
Hi Clabin,
Make sure you have all the same PHP modules and packages installed for the newer PHP version.
dpkg -l | grep php should show you all installed PHP packages, and compare your old version with the newly installed version.
The error message says that it can’t find the PHP driver to connect to the DB.
Also make sure to restart your apache-php setup after successful installation, to enable the additional modules.
Edit: the gists are kind of useless, as long as we don’t know how they’ve been created. There can be a difference in version between the PHP version on the CLI and the one being used in Apache. Have a look at this other topic with a simliar problem:
I updated my PHP to version 7.3, now I get the following error:
Exception occurred while logging exception: Failed to connect to the database: An exception occured in driver: could not find driver
#0 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(992): OC\DB\Connection->connect()
#1 /var/www/owncloud/lib/private/DB/Connection.php(207): Doctrine\DBAL\Connection->executeUpdate(‘PRAGMA read_unc…’, Array, Array)
#2 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): OC\DB\Connection->executeUpdate(‘PRAGMA read_unc…’)
#3 /var/www/owncloud/lib/private/DB/Connection.php(144): Doctrine\DBAL\Connection->setTransactionIsolation(2)
#4 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\DB\Connection->__construct(Array, Object(Doctrine\DBAL\Driver\PDOSqlite\Driver), Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager))
#5 /var/www/owncloud/lib/private/DB/ConnectionFactory.php(145): Doctrine\DBAL\DriverManager::getConnection(Array, Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager))
#6 /var/www/owncloud/lib/private/Server.php(531): OC\DB\ConnectionFactory->getConnection(‘sqlite3’, Array)
#7 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC{closure}(Object(OC\Server))
#8 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet(‘DatabaseConnect…’)
#9 /var/www/owncloud/lib/private/ServerContainer.php(86): OC\AppFramework\Utility\SimpleContainer->query(‘DatabaseConnect…’)
10 /var/www/owncloud/lib/private/Server.php(1216): OC\ServerContainer->query(‘DatabaseConnect…’)
#11 /var/www/owncloud/lib/private/Server.php(405): OC\Server->getDatabaseConnection()
#12 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC{closure}(Object(OC\Server))
#13 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet(‘AppConfig’)
#14 /var/www/owncloud/lib/private/ServerContainer.php(86): OC\AppFramework\Utility\SimpleContainer->query(‘AppConfig’)
#15 /var/www/owncloud/lib/private/Server.php(1146): OC\ServerContainer->query(‘AppConfig’)
#16 /var/www/owncloud/lib/private/Server.php(586): OC\Server->getAppConfig()
#17 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC{closure}(Object(OC\Server))
#18 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet(‘AppManager’)
#19 /var/www/owncloud/lib/private/ServerContainer.php(86): OC\AppFramework\Utility\SimpleContainer->query(‘AppManager’)
#20 /var/www/owncloud/lib/private/Server.php(1414): OC\ServerContainer->query(‘AppManager’)
#21 /var/www/owncloud/lib/private/legacy/app.php(343): OC\Server->getAppManager()
#22 /var/www/owncloud/lib/private/legacy/app.php(107): OC_App::getEnabledApps()
#23 /var/www/owncloud/lib/base.php(577): OC_App::loadApps(Array)
#24 /var/www/owncloud/lib/base.php(996): OC::init()
#25 /var/www/owncloud/index.php(53): require_once(‘/var/www/ownclo…’)
#26 {main}
What can I do?
Thank you
Did you read this line in the last post before yours?
So you should downgrade php to 7.2 or, if this is not a productive environment, you might want to upgrade to ownCloud 10.3 RC1:
additional to the hint given by @cortho i think you should make sure when upgrading a PHP installation from e.g. 7.0 to a later version that all required PHP extensions are installed for the new PHP version:
https://doc.owncloud.org/server/10.2/admin_manual/installation/manual_installation.html#php-extensions
It seems to me that users are constantly struggling with the “Failed to connect to the database: An exception occured in driver: could not find driver” message because they are missing this step when upgrading PHP.
i don’t think this problem is related to the original question. Maybe a moderator can move this into a new thread?
I agree with you, however this doesn’t seem to exist in the admin post edit section.
Anyway, enough off topic, I’m closing this topic.
@Clabin please open a new topic, especially if you have a new problem
