Owncloud10 nas on raspberry pi 3model b
it seems you have forgot to add your question and missed to fill out the information in the template.
I’m also not sure but depending on your question the https://central.owncloud.org/c/server category could better fit as the “Server-Apps” category is used for specific apps like the Market, Contacts, Calendar Apps and similar which are installed in ownCloud.
