Hi, i try sync folder by terminal and i have problem:
owncloudcmd /root/Projekt/ http://127.0.0.1/owncloud/remote.php/webdav/Projekt
i have anser
10-13 15:36:01:311 Passing NO proxy to csync for "http://127.0.0.1/owncloud/remote.php/webdav/Projekt"
10-13 15:36:01:314 Columns in the current journal: ("phash", "pathlen", "path", "inode", "uid", "gid", "mode", "modtime", "type", "md5", "fileid")
10-13 15:36:01:315 Transaction Start "checkConnect"
10-13 15:36:01:398 Columns in the current journal: ("phash", "pathlen", "path", "inode", "uid", "gid", "mode", "modtime", "type", "md5", "fileid")
10-13 15:36:01:399 =====sync DB has only 0 items, enable recursive PROPFIND if csync supports it
10-13 15:36:01:400 #### Update start #################################################### >>
10-13 15:36:01:400 csync_update: Journal: /root/Projekt/.csync_journal.db
10-13 15:36:01:402 csync_memstat_check: Memory: 122428K total size, 24360K resident, 21464K shared
10-13 15:36:01:402 csync_update: No exclude file loaded or defined!
10-13 15:36:01:402 sqlite_profile: _SQL_ SELECT * FROM metadata WHERE phash=?1: 0
10-13 15:36:01:402 csync_walker: file: /root/Projekt/.Metallica - Nothing Else Matters [Official Music Video].avi.~1c69fb81 [file_id=]
10-13 15:36:01:403 sqlite_profile: _SQL_ SELECT * FROM metadata WHERE phash=?1: 0
10-13 15:36:01:403 _csync_detect_update: Checking for rename based on inode # 1052674
10-13 15:36:01:403 sqlite_profile: _SQL_ SELECT * FROM metadata WHERE inode=?1: 0
10-13 15:36:01:403 _csync_detect_update: file: .Metallica - Nothing Else Matters [Official Music Video].avi.~1c69fb81, instruction: INSTRUCTION_NEW <<=
10-13 15:36:01:403 csync_walker: file: /root/Projekt/.Metallica - Nothing Else Matters [Official Music Video].mp3.~46b52dfb [file_id=]
10-13 15:36:01:403 _csync_detect_update: Checking for rename based on inode # 1052675
10-13 15:36:01:404 sqlite_profile: _SQL_ SELECT * FROM metadata WHERE inode=?1: 0
10-13 15:36:01:404 _csync_detect_update: file: .Metallica - Nothing Else Matters [Official Music Video].mp3.~46b52dfb, instruction: INSTRUCTION_NEW <<=
10-13 15:36:01:404 sqlite_profile: _SQL_ SELECT * FROM metadata WHERE phash=?1: 0
10-13 15:36:01:404 csync_walker: file: /root/Projekt/.asdfs.txt.~1e23ef54 [file_id=]
10-13 15:36:01:404 _csync_detect_update: Checking for rename based on inode # 1052676
10-13 15:36:01:404 _csync_detect_update: file: .asdfs.txt.~1e23ef54, instruction: INSTRUCTION_NEW <<=
10-13 15:36:01:404 csync_ftw: <= Closing walk for /root/Projekt with read_from_db 0
10-13 15:36:01:405 csync_update: Update detection for local replica took 0,00 seconds walking 3 files.
10-13 15:36:01:405 csync_memstat_check: Memory: 122428K total size, 24484K resident, 21464K shared
10-13 15:36:01:405 oc_module: opendir method called on owncloud://127.0.0.1/owncloud/remote.php/webdav/Projekt
10-13 15:36:01:405 oc_module: * scheme owncloud
10-13 15:36:01:405 oc_module: * host 127.0.0.1
10-13 15:36:01:405 oc_module: * port 0
10-13 15:36:01:405 oc_module: * path /owncloud/remote.php/webdav/Projekt
10-13 15:36:01:405 oc_module: * user
10-13 15:36:01:405 oc_module: Timeout set to 300 seconds
10-13 15:36:01:405 oc_module: No proxy configured.
10-13 15:36:01:405 oc_module: fetch_resource_list_recursive Starting recursive propfind owncloud://127.0.0.1/owncloud/remote.php/webdav/Projekt /owncloud/remote.php/webdav/Projekt
10-13 15:36:01:502 oc_module: Authentication required
10-13 15:36:01:502 oc_module: Call the csync callback for ownCloud
** Authentication required:
Enter your username:
i give login next:
Enter your password:
i give password next:
10-13 15:38:32:828 oc_module: Recursive propfind result code 207.
10-13 15:38:32:828 oc_module: fill_recursive_propfind_cache /owncloud/remote.php/webdav/Projekt Server maybe did not give us an 'infinity' depth result
10-13 15:38:32:828 oc_module: get_listdir_context_from_recursive_cache No element /owncloud/remote.php/webdav/Projekt in cache found
10-13 15:38:32:828 oc_module: clear_propfind_recursive_cache Invalidating..
10-13 15:38:33:110 oc_module: Simple propfind result code 207.
10-13 15:38:33:110 oc_module: opendir returning handle 0xb002b768 (count=4)
10-13 15:38:33:110 csync_walker: file: owncloud://127.0.0.1/owncloud/remote.php/webdav/Projekt/asdfs.txt [file_id=00000514ocnupo5p8ron]
10-13 15:38:33:110 sqlite_profile: _SQL_ SELECT * FROM metadata WHERE phash=?1: 0
10-13 15:38:33:111 sqlite_profile: _SQL_ SELECT * FROM metadata WHERE fileid=?1: 1000000
10-13 15:38:33:111 _csync_detect_update: file: asdfs.txt, instruction: INSTRUCTION_NEW <<=
10-13 15:38:33:111 csync_walker: file: owncloud://127.0.0.1/owncloud/remote.php/webdav/Projekt/Metallica - Nothing Else Matters [Official Music Video].mp3 [file_id=00000519ocnupo5p8ron]
10-13 15:38:33:111 sqlite_profile: _SQL_ SELECT * FROM metadata WHERE phash=?1: 0
10-13 15:38:33:111 sqlite_profile: _SQL_ SELECT * FROM metadata WHERE fileid=?1: 0
10-13 15:38:33:111 _csync_detect_update: file: Metallica - Nothing Else Matters [Official Music Video].mp3, instruction: INSTRUCTION_NEW <<=
10-13 15:38:33:111 csync_walker: file: owncloud://127.0.0.1/owncloud/remote.php/webdav/Projekt/Metallica - Nothing Else Matters [Official Music Video].avi [file_id=00000518ocnupo5p8ron]
10-13 15:38:33:111 _csync_detect_update: file: Metallica - Nothing Else Matters [Official Music Video].avi, instruction: INSTRUCTION_NEW <<=
10-13 15:38:33:111 csync_ftw: <= Closing walk for owncloud://127.0.0.1/owncloud/remote.php/webdav/Projekt with read_from_db 0
10-13 15:38:33:111 csync_update: Update detection for remote replica took 5,03 seconds walking 3 files.
10-13 15:38:33:111 csync_memstat_check: Memory: 122436K total size, 24028K resident, 20972K shared
10-13 15:38:33:112 <<#### Update end #################################################### 5032
10-13 15:38:33:112 _csync_merge_algorithm_visitor: INSTRUCTION_NEW file: .asdfs.txt.~1e23ef54
10-13 15:38:33:112 _csync_merge_algorithm_visitor: INSTRUCTION_NEW file: .Metallica - Nothing Else Matters [Official Music Video].mp3.~46b52dfb
10-13 15:38:33:112 _csync_merge_algorithm_visitor: INSTRUCTION_NEW file: .Metallica - Nothing Else Matters [Official Music Video].avi.~1c69fb81
10-13 15:38:33:112 csync_reconcile: Reconciliation for local replica took 0,00 seconds visiting 3 files.
10-13 15:38:33:112 _csync_merge_algorithm_visitor: INSTRUCTION_NEW file: asdfs.txt
10-13 15:38:33:112 _csync_merge_algorithm_visitor: INSTRUCTION_NEW file: Metallica - Nothing Else Matters [Official Music Video].avi
10-13 15:38:33:112 _csync_merge_algorithm_visitor: INSTRUCTION_NEW file: Metallica - Nothing Else Matters [Official Music Video].mp3
10-13 15:38:33:112 csync_reconcile: Reconciliation for remote replica took 0,00 seconds visiting 3 files.
10-13 15:38:33:113 Columns in the current journal: ("phash", "pathlen", "path", "inode", "uid", "gid", "mode", "modtime", "type", "md5", "fileid")
10-13 15:38:33:114 Transaction Start "checkConnect"
10-13 15:38:33:206 Columns in the current journal: ("phash", "pathlen", "path", "inode", "uid", "gid", "mode", "modtime", "type", "md5", "fileid")
10-13 15:38:33:208 Using QNAM/HTTP parallel code path
10-13 15:38:33:208 void Mirall::AbstractNetworkJob::setTimeout(qint64) 300000
10-13 15:38:33:218 !!! Mirall::PUTFileJob created for QUrl( "http://127.0.0.1/owncloud/" ) querying "Projekt/.Metallica - Nothing Else Matters [Official Music Video].avi.~1c69fb81"
10-13 15:38:33:219 void Mirall::AbstractNetworkJob::setTimeout(qint64) 300000
10-13 15:38:33:219 !!! Mirall::PUTFileJob created for QUrl( "http://127.0.0.1/owncloud/" ) querying "Projekt/.Metallica - Nothing Else Matters [Official Music Video].mp3.~46b52dfb"
10-13 15:38:33:220 void Mirall::AbstractNetworkJob::setTimeout(qint64) 300000
10-13 15:38:33:220 !!! Mirall::PUTFileJob created for QUrl( "http://127.0.0.1/owncloud/" ) querying "Projekt/.asdfs.txt.~1e23ef54"
10-13 15:38:33:458 void Mirall::AbstractNetworkJob::slotFinished() 204 "Host requires authentication"
10-13 15:38:33:458 void Mirall::PropagateUploadFileQNAM::slotPutFinished() QUrl( "http://127.0.0.1/owncloud/remote.php/webdav/Projekt/.asdfs.txt.~1e23ef54" ) FINISHED WITH STATUS 204 "Host requires authentication" QVariant(int, 401) QVariant(QString, "Unauthorized")
10-13 15:38:33:458 "<?xml version="1.0" encoding="utf-8"?>
<d:error xmlns:d="DAV:" xmlns:s="http://sabredav.org/ns" xmlns:o="http://owncloud.org/ns">
<s:exception>OCA\DAV\Connector\Sabre\Exception\PasswordLoginForbidden</s:exception>
<s:message/>
<o:hint xmlns:o="o:">password login forbidden</o:hint>
</d:error>
10-13 15:38:33:460 void Mirall::SyncEngine::slotJobCompleted(const Mirall::SyncFileItem&) ".asdfs.txt.~1e23ef54" 2 "Host requires authentication"
10-13 15:38:33:460 Object::connect: No such slot QCoreApplication::slotCredentialsFetched()
10-13 15:38:33:460 Error: User is emty!
10-13 15:38:33:460 InvalidateToken: User is empty, bailing out!
10-13 15:38:33:462 Strange: User is empty!
10-13 15:38:33:462 Error: User is emty!
10-13 15:38:33:462 virtual void Mirall::PropagateDownloadFileQNAM::start() "Metallica - Nothing Else Matters [Official Music Video].avi" 2
10-13 15:38:33:463 "INSERT OR REPLACE INTO downloadinfo (path, tmpfile, etag, errorcount) VALUES ( ? , ?, ? , ? )" "Metallica - Nothing Else Matters [Official Music Video].avi" ".Metallica - Nothing Else Matters [Official Music Video].avi.~1c69fb81" "15b8eed6aa6ed96fc0b9730f6a2b171c" 0
10-13 15:38:33:463 Transaction Start "download file start"
10-13 15:38:33:565 void Mirall::AbstractNetworkJob::setTimeout(qint64) 300000
10-13 15:38:33:565 !!! Mirall::GETFileJob created for QUrl( "http://127.0.0.1/owncloud/" ) querying "Projekt/Metallica - Nothing Else Matters [Official Music Video].avi"
10-13 15:38:33:566 Strange: User is empty!
10-13 15:38:33:566 QWidget: Cannot create a QWidget when no GUI is being used
Przerwane
and
what is wrong ??
