PHP errors when installing owncloud
Unable to install owncloud server, tried PHP 7.3 and 7.4
Always getting this error:
[Mon Feb 08 14:36:38.766679 2021] [php7:error] [pid 12740] [client 87.218.13.82:36850] PHP Fatal error: Cannot redeclare normalizer_normalize() (previously declared in /var/www/owncloud/lib/composer/symfony/polyfill-intl-normalizer/bootstrap.php:18) in /var/www/owncloud/lib/composer/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php on line 21
Ubuntu 18.04.5 LTS
Apache
MariaDB 10.5.8
PHP 7.4.15 (cli) (built: Feb 7 2021 12:21:51) ( NTS )
10.6
Fresh install
Did you install all required packages? For the php version you use? Have a look at Redirect Notice
To me it seems at least php-intl is missing.
In case you still cannot get it running, please
  • make sure you are using the same php version for both apache and command line
  • provide the output of
  • php -m
Additionally, please have a look at the two threads you already opened Integrity Failed and Ownlcoud logs warnings & errors
I’d consider it as a good move to drop at least a small comment, if the advice you got was helpful/working or not.
Hello! Thank you very much for your reply. Yes, I think I had all the php modules installed, here is a list I got with php -m:
[PHP Modules]
calendar
Core
ctype
curl
date
dom
exif
FFI
fileinfo
filter
ftp
gd
gettext
hash
iconv
igbinary
imagick
intl
json
libxml
mbstring
mysqli
mysqlnd
openssl
pcntl
pcre
PDO
pdo_mysql
Phar
posix
readline
redis
Reflection
session
shmop
SimpleXML
sockets
sodium
SPL
ssh2
standard
sysvmsg
sysvsem
sysvshm
tokenizer
xml
xmlreader
xmlwriter
xsl
Zend OPcache
zip
zlib
[Zend Modules]
Zend OPcache
php -v
Copyright © The PHP Group
Zend Engine v3.4.0, Copyright © Zend Technologies
with Zend OPcache v7.4.15, Copyright ©, by Zend Technologies
Checking Apache version with phpinfo():
Configuration File (php.ini) Path /etc/php/7.2/apache2
Loaded Configuration File /etc/php/7.2/apache2/php.ini
Scan this dir for additional .ini files /etc/php/7.2/apache2/conf.d
It seems that didn´t match the PHP version of Apache with the PHP in command line. have updated the PHP version of the Apache web server, from 7.2 to 7.4:
To enable php7.4: a2enmod php7.4
To disable php7.2: a2dismod php7.2
Restart apache.
Now this is my configuration in Apache:
Configuration File (php.ini) Path /etc/php/7.4/apache2
Loaded Configuration File /etc/php/7.4/apache2/php.ini
Scan this dir for additional .ini files /etc/php/7.4/apache2/conf.d
I could see now the ownCloud installation page, instead of the blank page I got before when I had PHP errors.
