Powerpoint files silently deleted in 10.0.10 web interface
  1. Log in to web client
  2. Upload a Powerpoint (*.pptx) file
  3. Watch as the file is silently deleted.
  1. Using the Desktop app, copy a Powerpoint (*.pptx) file to an ownCloud folder
  2. Log in to web client
  3. Navigate to folder containing the Powerpoint file
  4. Watch as the file is silently deleted (and receive notice from the Desktop app that the file has been deleted).
I’ve been unable to reproduce this problem with PDF, Excel, Word or graphics files–only Powerpoint.
File should remain unless explicitly removed.
File is silently deleted with no warnings or messages in the web UI.
CentOS 6
Apache
PostgreSQL
5.6.38 (installed from Webtatic repository)
10.0.10.4
Updated from older ownCloud.
Tarball.
    "system": {
        "datadirectory": "\/var\/www\/html\/example.com\/owncloud-data",
        "dbtype": "pgsql",
        "version": "10.0.10.4",
        "dbname": "owncloud_comp",
        "dbhost": "\/tmp",
        "dbtableprefix": "oc_",
        "installed": true,
        "instanceid": "5089a7387620f",
        "maintenance": false,
        "forcessl": true,
        "share_folder": "\/Shared",
        "maxZipInputSize": 838860800,
        "allowZipDownload": true,
        "trusted_domains": [
            "owncloud.example.com"
        "overwrite.cli.url": "https:\/\/owncloud.example.com\/",
        "cron_log": true,
        "logtimezone": "America\/Edmonton",
        "theme": "",
        "mail_smtpmode": "php",
        "has_internet_connection": true,
        "appstoreenabled": true,
        "apps_paths": [
                "path": "\/var\/www\/html\/example.com\/owncloud\/apps",
                "url": "\/apps",
                "writable": true
        "updatechecker": true,
        "default_language": "en",
        "defaultapp": "files",
        "enable_previews": true,
        "preview_libreoffice_path": "\/usr\/bin\/libreoffice",
        "enabledPreviewProviders": [
            "OC\\Preview\\PNG",
            "OC\\Preview\\JPEG",
            "OC\\Preview\\BMP",
            "OC\\Preview\\XBitmap",
            "OC\\Preview\\MP3",
            "OC\\Preview\\TXT",
            "OC\\Preview\\MarkDown",
            "OC\\Preview\\PDF",
            "OC\\Preview\\MSOffice2003",
            "OC\\Preview\\MSOffice2007",
            "OC\\Preview\\MSOfficeDoc",
            "OC\\Preview\\OpenDocument"
        "cache_path": "",
        "filesystem_check_changes": 1,
        "asset-pipeline.enabled": true,
        "mount_file": "data\/mount.json",
        "redis": {
            "0": "tmp\/redis.sock",
            "timeout": 0,
            "dbindex": 0
        "filelocking.enabled": true,
        "loglevel": 2,
        "trashbin_retention_obligation": "auto"
IEnabled:
  - activity: 2.3.8
  - comments: 0.3.0
  - configreport: 0.1.1
  - dav: 0.4.0
  - federatedfilesharing: 0.3.1
  - federation: 0.1.0
  - files: 1.5.1
  - files_external: 0.7.1
  - files_pdfviewer: 0.9.0
  - files_sharing: 0.11.0
  - files_texteditor: 2.2.1
  - files_trashbin: 0.9.1
  - files_versions: 1.3.0
  - files_videoplayer: 0.9.8
  - firstrunwizard: 1.1
  - gallery: 16.1.0
  - market: 0.2.5
  - notifications: 0.3.5
  - provisioning_api: 0.5.0
  - systemtags: 0.3.0
  - templateeditor: 0.3.1
  - updatenotification: 0.2.1
  - user_ldap: 0.11.0
Disabled:
  - encryption
  - external
  - user_external
Allowing Google Drive and CIFS/SMBFS
No.
Yes, LDAP.
| Configuration                 |        |
| hasMemberOfFilterSupport      |        |
| hasPagedResultSupport         |        |
| homeFolderNamingRule          | attr:uid        |
| lastJpegPhotoLookup           | 0        |
| ldapAgentName                 | *** REMOVED SENSITIVE DATA ***                                                        |
| ldapAgentPassword             | ***        |
| ldapAttributesForGroupSearch  |        |
| ldapAttributesForUserSearch   |        |
| ldapBackupHost                |        |
| ldapBackupPort                | 636        |
| ldapBase                      | *** REMOVED ***        |
| ldapBaseGroups                | *** REMOVED ***        |
| ldapBaseUsers                 | *** REMOVED ***        |
| ldapCacheTTL                  | 600        |
| ldapConfigurationActive       | 1        |
| ldapDynamicGroupMemberURL     |        |
| ldapEmailAttribute            | mail        |
| ldapExperiencedAdmin          | 0        |
| ldapExpertUUIDGroupAttr       | entryUUID        |
| ldapExpertUUIDUserAttr        | entryUUID        |
| ldapExpertUsernameAttr        | uid        |
| ldapGroupDisplayName          | cn        |
| ldapGroupFilter               | (&(|(objectclass=groupOfNames)))        |
| ldapGroupFilterGroups         |        |
| ldapGroupFilterMode           | 0        |
| ldapGroupFilterObjectclass    | groupOfNames        |
| ldapGroupMemberAssocAttr      | member        |
| ldapHost                      | ldaps://host.example.com        |
| ldapIgnoreNamingRules         |        |
| ldapLoginFilter               | (&(&(objectClass=Person)(!(objectClass=calEntry)))(|(uid=%uid)(|(mailPrimaryAddress=%uid)(mail=%uid)))) |
| ldapLoginFilterAttributes     |        |
| ldapLoginFilterEmail          | 1        |
| ldapLoginFilterMode           | 0        |
| ldapLoginFilterUsername       | 1        |
| ldapNestedGroups              | 0        |
| ldapOverrideMainServer        | 0        |
| ldapPagingSize                | 500        |
| ldapPort                      | 636        |
| ldapQuotaAttribute            |        |
| ldapQuotaDefault              |        |
| ldapTLS                       |        |
| ldapUserDisplayName           | cn        |
| ldapUserDisplayName2          |        |
| ldapUserFilter                | (|(objectclass=inetOrgPerson)(objectclass=organizationalPerson)(objectclass=person))                    |
| ldapUserFilterGroups          |        |
| ldapUserFilterMode            | 0        |
| ldapUserFilterObjectclass     | inetOrgPerson;organizationalPerson;person                                                               |
| ldapUuidGroupAttribute        | auto        |
| ldapUuidUserAttribute         | auto        |
| turnOffCertCheck              | 0        |
| useMemberOfToDetectMembership | 0        |
Tried Firefox or Chrome.
Windows 7/10
No errors present for the time period in question.
{"reqId":"M3DTBQPQPNdDzsOr0nR5","level":3,"time":"2018-10-30T08:45:46-06:00","remoteAddr":"192.168.60.129","user":"nels","app":"core","method":"GET","url":"\/remote.php\/dav\/files\/nels\/Horde\/IT%20Tickets%20Final.pptx?c=6f2248f908d3d345876fa168b34e2ba9&x=32&y=32&forceIcon=0&preview=1","message":"unable to open image `\/tmp\/IT Tickets Final.pdf': No such file or directory @ error\/blob.c\/OpenBlob\/2589"}
{"reqId":"7kktAYeoPeaXviii9wHT","level":3,"time":"2018-10-30T08:47:02-06:00","remoteAddr":"192.168.60.129","user":"nels","app":"core","method":"GET","url":"\/remote.php\/dav\/files\/nels\/Personal\/FedEx%20Contract%20notice%20Jul%202009%20%28Draft%202%29.doc?c=5bd796f0254a1&x=32&y=32&forceIcon=0&preview=1","message":"unable to open image `\/tmp\/oc_tmp_nXlBF2.pdf': No such file or directory @ error\/blob.c\/OpenBlob\/2589"}
Given the behaviour seems to be browser agnostic, I’m not bothering with this.
i’m not sure how much of a help a user based support forum like this can help with such issues. :confused:
Personally i would always report such issues to a bug tracker instead. AFAIK the bugtracker of ownCloud and the component (the server) is located here: https://github.com/owncloud/core/issues
Hey, there was always a possibility I missed some obscure configuration tweak after upgrading from the 9.1.x series that someone would immediately jump on! :grinning:
But your point is well taken; I’ll report it through the bugtracking system as well.
hehe indeed. But i think a file should never just vanish / be deleted automatically like you’re seeing it.
Sounds great. i think its always good if we users are reporting such issues to bug trackers to share our experience while running a software like ownCloud.
