unfortunately one of my pc was infected by cryptolocker that crypted almost all .doc,.xls files on owncloud folder.
So I was using the restore function of owncloud to restore all files that cryptolocker “deleted” (because it renames the original file).
I should restore more or less 2200 files. I tried to check all files in the owncloud web ui and do restore. It doesn’t work! ![]()
So I tried to restore 5-10 files at time. Doing that I’ve some problems:
- the ui after the restore became unusable and checkboxes disappears from each file. So every time I’ve to realod the web page.
- Sometimes I’ve to do the restore many times for the same file before it is correctly restored
- I’ve some errors in the logs:
Exception: {“Exception”:“OCP\Lock\LockedException”,“Message”:" "scanner::d3720e2213aa8618ce913a873309589b" is locked",“Code”:0,“Trace”:“#0 /var/www/html/owncloud/lib/private/files/cache/scanner.php(264): OC\Lock\DBLockingProvider->acquireLock(‘scanner::d3720e…’, 2)\n#1 /var/www/html/owncloud/apps/files_trashbin/lib/trashbin.php(764): OC\Files\Cache\Scanner->scan(‘files_trashbin/…’)\n#2 /var/www/html/owncloud/apps/files_trashbin/lib/trashbin.php(436): OCA\Files_Trashbin\Trashbin::getVersionsFromTrash(‘FATTURA 31 BORG…’, ‘1479776953’, ‘bluenergy’)\n#3 /var/www/html/owncloud/apps/files_trashbin/lib/trashbin.php(388): OCA\Files_Trashbin\Trashbin::restoreVersions(Object(OC\Files\View), ‘//FATTURA 31 BO…’, ‘FATTURA 31 BORG…’, ‘FATTURA 31 BORG…’, ‘FATTURE e DDT/F…’, ‘1479776953’)\n#4 /var/www/html/owncloud/apps/files_trashbin/ajax/undelete.php(72): OCA\Files_Trashbin\Trashbin::restore(‘//FATTURA 31 BO…’, ‘FATTURA 31 BORG…’, ‘1479776953’)\n#5 /var/www/html/owncloud/lib/private/route/route.php(154) : runtime-created function(1): require_once(‘/var/www/html/o…’)\n#6 [internal function]: __lambda_func(Array)\n#7 /var/www/html/owncloud/lib/private/route/router.php(291): call_user_func(‘?lambda_204’, Array)\n#8 /var/www/html/owncloud/lib/base.php(853): OC\Route\Router->match(‘/apps/files_tra…’)\n#9 /var/www/html/owncloud/index.php(39): OC::handleRequest()\n#10 {main}”,“File”:“/var/www/html/owncloud/lib/private/lock/dblockingprovider.php”,“Line”:183} 2016-11-22T17:29:45+00:00
Error trashbin can’t restore FATTURA 41 .xls 2016-11-22T17:28:48+00:00
Error files_trashbin trash bin database inconsistent!
Anyway it’s strange because even if I’ve errors the restore happens correclty.
Of course restoring files in this way will takes years
Do you have some suggestion to solve the problem?
My owncloud version is 8.2.7 (stable).
