I think the easiest thing to do at this point is to backup your data, forget the database, install a fresh owncloud 10.0.3 with my scripts and be happy. My scripts won’t fail. I use them daily.
Searching for the error you have in your configuration is very difficult for me without hands on.
Yes, it works perfectly, but now during the upgrade for backup … I have this message:
Doctrine\DBAL\Exception\UniqueConstraintViolationException: An exception occurred while executing ‘INSERT INTO oc_file_locks (key,lock,ttl) SELECT ?,?,? FROM oc_file_locks WHERE key = ? HAVING COUNT(*) = 0’ with params [“files/ef2805553d8d69d4768cdfe9af223809”, -1, 1508453042, “files/ef2805553d8d69d4768cdfe9af223809”]: SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry ‘0’ for key ‘PRIMARY’
this is the log
Update preparation
Set the log level to debug
Maintenance Mode Enabled
Database schema update
Updated database
[1/28]: Drop old database table: calendar_calendars
[2/28]: Drop old database table: calendar_objects
[3/28]: Drop old database table: calendar_share_calendar
[4/28]: Drop old database table: calendar_share_event
[5/28]: Drop old database table: file_map
[6/28]: Drop old database table: foldersize
[7/28]: Drop old database table: fscache
[8/28]: Drop old database table: gallery_sharing
[9/28]: Drop old database table: locks
[10/28]: Drop old database table: log
[11/28]: Drop old database table: media_albums
[12/28]: Drop old database table: media_artists
[13/28]: Drop old database table: media_sessions
[14/28]: Drop old database table: media_songs
[15/28]: Drop old database table: media_users
[16/28]: Drop old database table: permissions
[17/28]: Drop old database table: pictures_images_cache
[18/28]: Drop old database table: principalgroups
[19/28]: Drop old database table: principals
[20/28]: Drop old database table: queuedtasks
[21/28]: Drop old database table: sharing
[22/28]: Drop old database table: clndr_calendars
[23/28]: Drop old database table: clndr_objects
[24/28]: Drop old database table: clndr_share_event
[25/28]: Drop old database table: clndr_share_calendar
[26/28]: Drop old database table: clndr_repeat
[27/28]: Drop old database table: contacts_addressbooks
[28/28]: Drop old database table: contacts_cards
[28/28]: Drop old database tables
[1/2]: Fix permissions so avatars can be stored again
[1/1]: Fix permissions so avatars can be stored again
[1/3]: Move user avatars outside the homes to the new location
Doctrine \ DBAL \ Exception \ UniqueConstraintViolationException: An exception occurred while executing 'INSERT INTO oc_file_locks ( key, lock, ttl) SELECT?,?,? FROM oc_file_locks WHERE key =? HAVING COUNT (*) = 0 ‘with params [“files \ / ef2805553d8d69d4768cdfe9af223809”, -1, 1508453042, “files \ / ef2805553d8d69d4768cdfe9af223809”]: SQLSTATE [23000]: Integrity constraint violation: 1062 Duplicate entry’ 0 ‘for key’ ’
The oc_file_locks-table is just to handle open files. If you make sure that you don’t have any clients connected, you should be save by cleaning this table. For performance reasons, it’s better to use redis as a file-locking cache.
Now I do some research, I will have to do so, because I’m also accessing the cloud (with the inserted date folder) but with a new config.php file (the old one has the database schema and does not let me see the login page) using the old username and password I do not see the data I entered in the old formatting
Doctrine\DBAL\Exception\TableNotFoundException: An exception occurred while executing ‘INSERT INTO oc_file_locks (key,lock,ttl) SELECT ?,?,? FROM oc_file_locks WHERE key = ? HAVING COUNT(*) = 0’ with params [“files/5f6ee1e490e9ca69dd54703bc805cfff”, 1, 1508525925, “files/5f6ee1e490e9ca69dd54703bc805cfff”]: SQLSTATE[42S02]: Base table or view not found: 1146 Table ‘owncloud.oc_file_locks’ doesn’t exist
You have your data, right? I mean the files. That you copied from your backup.
Leave the database. Start a new one. We are now on post 158. It starts to feel like professional support at this point. This is not the porpoise of this forum. You need to do some research.
