Hi, I have a problem with the webdav using Lightning.
Thank you for the help ![]()
- Tried to import an Owncloud calendar in Thunderbird/Lightning
- Login Window appeared
- Filled in username and pw and the window appears again without any effect.
Should import the calendar from OC
Login window is reappearing
Operating system: Raspbian
Web server: Nginx
Database: SQLite
PHP version: PHP 5
Updated from an older ownCloud or fresh install: 9.0
used this code to configure the cloud: http://www.sempervideo.de/pi-owncloud.txt
external storage enabled
Integrity status for oC9+
paste the results here.
-> No errors have been found.
Error log from webdav attempts:
Exception: {“Message”:“HTTP/1.1 405 The resource you tried to create
already
exists”,“Exception”:“Sabre\DAV\Exception\MethodNotAllowed”,“Code”:0,“Trace”:"#0
/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(588):
Sabre\DAV\Server->createCollection(‘Uni/Module HS 1…’,
Object(Sabre\DAV\MkCol))\n#1 [internal function]:
Sabre\DAV\CorePlugin->httpMkcol(Object(Sabre\HTTP\Request),
Object(Sabre\HTTP\Response))\n#2
/var/www/owncloud/3rdparty/sabre/event/lib/EventEmitterTrait.php(105):
call_user_func_array(Array, Array)\n#3
/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(459):
Sabre\Event\EventEmitter->emit(‘method:MKCOL’, Array)\n#4
/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php(248):
Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request),
Object(Sabre\HTTP\Response))\n#5
/var/www/owncloud/apps/dav/appinfo/v1/webdav.php(56):
Sabre\DAV\Server->exec()\n#6 /var/www/owncloud/remote.php(164):
require_once(‘/var/www/ownclo…’)\n#7
{main}“,“File”:”/var/www/owncloud/3rdparty/sabre/dav/lib/DAV/Server.php",“Line”:1121,“User”:“XXXX”}
