Setup:
Dockerized set of owncloud 10.0.10.4 (docker image tag 10.0), mariadb, nginx-proxy and letsencrypt-nginx-proxy-companion and redis, fresh install. Plain http between proxy and owncloud.
Problem:
Testfile with name üü.xlsx and size 16.5MB.
Initial upload (INSTRUCTION_NEW) proceeds fine, after modifying the file and saving it client (2.5.0 and 2.5.1)
fails to upload it. At first progression bar quickly moves to the end and then after some time client displays message: “Connection timed out”.
If file size is less than 10 000 000 bytes (no chunking) or it does not contain special characters, syncing succeeds.
Notes:
When syncing fails, chunks are present in user’s uploads directory.
From logs (both client and server side) I see that initial successful sync contains MKCOL followed by 2x PUT chunks followed by MOVE; consecutive syncs that fail never show MOVE on server side, it is present on client log though. Can’t see any errors server side with log level 0, except for non-existent tokens.
Same version of owncloud without nginx proxy works fine, also same setup with nginx-proxy but without ssl encryption works fine. Thanks for any ideas what to check or how to proceed.
Example of success (client side):
|12-18 14:34:16:548 [ info sync.checksums ]:|Computing "SHA1" checksum of "C:/test1/üü.xlsx" in a thread|
|12-18 14:34:16:627 [ info sync.accessmanager ]:|6 "MKCOL" "https_://test.example.com/remote.php/dav/uploads/test1/3475914426" has X-Request-ID "e61c5951-b3b9-4c72-8947-21a81b251895"|
|12-18 14:34:16:628 [ info sync.networkjob ]:|OCC::MkColJob created for "https_://test.example.com" + "" "OCC::PropagateUploadFileNG"|
|12-18 14:34:16:698 [ info sync.networkjob.mkcol ]:|MKCOL of QUrl("https_://test.example.com/remote.php/dav/uploads/test1/3475914426") FINISHED WITH STATUS "OK"|
|12-18 14:34:16:711 [ info sync.accessmanager ]:|3 "" "https_://test.example.com/remote.php/dav/uploads/test1/3475914426/00000000" has X-Request-ID "fdabac02-4f2c-4da9-95e8-6a6f8431fb06"|
|12-18 14:34:16:713 [ info sync.networkjob ]:|OCC::PUTFileJob created for "https_://test.example.com" + "" "OCC::PropagateUploadFileNG"|
|12-18 14:34:17:156 [ info sync.networkjob.put ]:|PUT of "https_://test.example.com/remote.php/dav/uploads/test1/3475914426/00000000" FINISHED WITH STATUS "OK" QVariant(int, 201) QVariant(QString, "")|
|12-18 14:34:17:158 [ info sync.propagator.upload ]:|Chunked upload of 10000000 bytes took 446 ms, desired is 60000 ms, expected good chunk size is 1345291479 bytes and nudged next chunk size to 100000000 bytes|
|12-18 14:34:17:167 [ info sync.accessmanager ]:|3 "" "https_://test.example.com/remote.php/dav/uploads/test1/3475914426/00000001" has X-Request-ID "f403005a-b29b-4569-9379-d7d41f8247a7"|
|12-18 14:34:17:169 [ info sync.networkjob ]:|OCC::PUTFileJob created for "https_://test.example.com" + "" "OCC::PropagateUploadFileNG"|
|12-18 14:34:17:486 [ info sync.networkjob.put ]:|PUT of "https_://test.example.com/remote.php/dav/uploads/test1/3475914426/00000001" FINISHED WITH STATUS "OK" QVariant(int, 201) QVariant(QString, "")|
|12-18 14:34:17:488 [ info sync.propagator.upload ]:|Chunked upload of 7322065 bytes took 319 ms, desired is 60000 ms, expected good chunk size is 1377190909 bytes and nudged next chunk size to 100000000 bytes|
|12-18 14:34:17:490 [ info sync.propagator.upload ]:|"//remote.php/dav/files/test1/üü.xlsx" "SHA1:aec65c62971a7d4a412df01cd4233aabe274677d"|
|12-18 14:34:17:492 [ info sync.accessmanager ]:|6 "MOVE" "https_://test.example.com/remote.php/dav/uploads/test1/3475914426/.file" has X-Request-ID "0f56f80b-cb1e-4f17-a4e2-885ceba16db3"|
|12-18 14:34:17:493 [ info sync.networkjob ]:|OCC::MoveJob created for "https_://test.example.com" + "" "OCC::PropagateUploadFileNG"|
|12-18 14:34:18:026 [ info sync.networkjob.move ]:|MOVE of QUrl("https_://test.example.com/remote.php/dav/uploads/test1/3475914426/.file") FINISHED WITH STATUS "OK"|
|12-18 14:34:18:026 [ info sync.database ]:|Updating file record for path: "\xC3\xBC\xC3\xBC.xlsx" inode: 578241 modtime: 1545126141 type: 0 etag: "86071964f0d21794742056c8838b95c1" fileId: "00000085oc8jncyfgxeq" remotePerm: "" fileSize: 17322065 checksum: "SHA1:aec65c62971a7d4a412df01cd4233aabe274677d"|
|12-18 14:34:18:026 [ info sync.propagator ]:|Completed propagation of "üü.xlsx" by OCC::PropagateUploadFileNG(0x8c04908) with status 4|
|12-18 14:34:18:037 [ info sync.database ]:|Closing DB "C:/test1/._sync_d5d6320b25a5.db"|
Example of failure (client side):
|12-18 14:35:53:258 [ info sync.propagator ]:|Starting INSTRUCTION_SYNC propagation of "üü.xlsx" by OCC::PropagateUploadFileNG(0x8c04b88)|
|12-18 14:35:53:259 [ info sync.checksums ]:|Computing "SHA1" checksum of "C:/test1/üü.xlsx" in a thread|
|12-18 14:35:53:324 [ info sync.accessmanager ]:|6 "MKCOL" "https_://test.example.com/remote.php/dav/uploads/test1/3474338122" has X-Request-ID "14d5078d-1074-4fc1-a95a-2195265839e1"|
|12-18 14:35:53:326 [ info sync.networkjob ]:|OCC::MkColJob created for "https_://test.example.com" + "" "OCC::PropagateUploadFileNG"|
|12-18 14:35:53:414 [ info sync.networkjob.mkcol ]:|MKCOL of QUrl("https_://test.example.com/remote.php/dav/uploads/test1/3474338122") FINISHED WITH STATUS "OK"|
|12-18 14:35:53:425 [ info sync.accessmanager ]:|3 "" "https_://test.example.com/remote.php/dav/uploads/test1/3474338122/00000000" has X-Request-ID "00df5ce7-1c14-4233-acd3-a93e664ba042"|
|12-18 14:35:53:426 [ info sync.networkjob ]:|OCC::PUTFileJob created for "https_://test.example.com" + "" "OCC::PropagateUploadFileNG"|
|12-18 14:35:53:900 [ info sync.networkjob.put ]:|PUT of "https_://test.example.com/remote.php/dav/uploads/test1/3474338122/00000000" FINISHED WITH STATUS "OK" QVariant(int, 201) QVariant(QString, "")|
|12-18 14:35:53:902 [ info sync.propagator.upload ]:|Chunked upload of 10000000 bytes took 476 ms, desired is 60000 ms, expected good chunk size is 1260504201 bytes and nudged next chunk size to 100000000 bytes|
|12-18 14:35:53:911 [ info sync.accessmanager ]:|3 "" "https_://test.example.com/remote.php/dav/uploads/test1/3474338122/00000001" has X-Request-ID "260d2b51-33c8-4450-97e7-8837a66a0fe9"|
|12-18 14:35:53:913 [ info sync.networkjob ]:|OCC::PUTFileJob created for "https_://test.example.com" + "" "OCC::PropagateUploadFileNG"|
|12-18 14:35:54:228 [ info sync.networkjob.put ]:|PUT of "https_://test.example.com/remote.php/dav/uploads/test1/3474338122/00000001" FINISHED WITH STATUS "OK" QVariant(int, 201) QVariant(QString, "")|
|12-18 14:35:54:228 [ info sync.propagator.upload ]:|Chunked upload of 7322089 bytes took 321 ms, desired is 60000 ms, expected good chunk size is 1368614766 bytes and nudged next chunk size to 100000000 bytes|
|12-18 14:35:54:228 [ info sync.propagator.upload ]:|"//remote.php/dav/files/test1/üü.xlsx" "SHA1:18e7e5ce4efd2f2da11476dbc0599044a8864a78"|
|12-18 14:35:54:228 [ info sync.accessmanager ]:|6 "MOVE" "https_://test.example.com/remote.php/dav/uploads/test1/3474338122/.file" has X-Request-ID "92ec0ffa-84e4-42ed-8927-e141f6bc6773"|
|12-18 14:35:54:238 [ info sync.networkjob ]:|OCC::MoveJob created for "https_://test.example.com" + "" "OCC::PropagateUploadFileNG"|
|12-18 14:36:05:088 [ info sync.accessmanager ]:|6 "PROPFIND" "https_://test.example.com/remote.php/dav/files/test1/" has X-Request-ID "61a9479e-8644-4742-96a5-608f1e73a150"|
|12-18 14:36:05:088 [ info sync.networkjob ]:|OCC::PropfindJob created for "https_://test.example.com" + "/" "OCC::QuotaInfo"|
|12-18 14:36:05:177 [ info sync.networkjob.propfind ]:|PROPFIND of QUrl("https_://test.example.com/remote.php/dav/files/test1/") FINISHED WITH STATUS "OK"|
