[Resolved] Again the max upload size above 2MB
Hello
I know there is plenti of tuto explaining how to do it but I have try them…
My conf : Ubuntu 18.04, Apache2, Owncloud 10.0.10
I try to change the 2MB limit in :
  • all the php.ini I found with “locate”
  • the .usrer.ini
    -the .htacess
But I still have a limitation to 2 MB!
No error message in the log file. No yellow warning on the page to say it is to big (the % bare graph goes from 0 to 100 but file did not apear)
No “PUT” request with the filename in the access log file (as it does appear with small file)
Any idea ?
Some more information :
The modification of the php.ini works as <?php phpinfo()?> indicate that post_max_size and upload_max_size are both to “16G”
maybe you could ask the support of your hoster to ask if they have some additional configuration in place which prevents your web server or PHP to allow ownCloud uploading larger files?
Thanks for reply but there is no hoster il the loop.
Owncloud is on my server.
ok so then i think the “Hosting area” chosen to post this topic is a little bit misplaced :slightly_smiling_face:. From what i know this should be used if you’re not running your own server but using an ownCloud installation on a hosting provider.
If i’m creating a new thread in this category i’m getting the template below presented. Maybe you could fill out the information asked within it so people are better able to help you?
I think especially the “logfiles” part could be useful.
Thanks for reporting issues back to ownCloud! This is the issue tracker of ownCloud, if you have any support question please check out https://owncloud.org/support
This is the bug tracker for the Server component. Find other components at https://github.com/owncloud/core/blob/master/.github/CONTRIBUTING.md#guidelines
For reporting potential security issues please see https://owncloud.org/security/
To make it possible for us to help you please fill out below information carefully.
Before reporting any issues please make sure that you're using the latest available version for your major branch (e.g. 9.0.x), see https://owncloud.org/changelog/
### Steps to reproduce
1.
2.
3.
### Expected behaviour
### Actual behaviour
### Server configuration
**Operating system**:
**Web server:**
**Database:**
**PHP version:**
**List of activated apps:**
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
#### Browser log
Sorry my mistake
I have removed the Hosted tag.
Here below the information :
1.Upload a file larger than 2Mb
2.The % bare apear but a the end the file is not in owncloud
3.No yellow warning in the upper part
The file should be present
The file if bigger than 2MB is not present
Ubuntu 18.04
**Web server:**
Apache 2
**Database:**
10.1.34-MariaDB-0ubuntu0.18.04.1
**PHP version:**
php 7.2
10.0.10.4
fresh install
wget
Enabled:
  - comments: 0.3.0
  - configreport: 0.1.1
  - dav: 0.4.0
  - federatedfilesharing: 0.3.1
  - federation: 0.1.0
  - files: 1.5.1
  - files_external: 0.7.1
  - files_sharing: 0.11.0
  - files_trashbin: 0.9.1
  - files_versions: 1.3.0
  - files_videoplayer: 0.9.8
  - firstrunwizard: 1.1
  - market: 0.2.5
  - notifications: 0.3.5
  - provisioning_api: 0.5.0
  - systemtags: 0.3.0
  - updatenotification: 0.2.1
Disabled:
  - encryption
  - external
  - user_external
only nfs
no
no
**Browser:**
firefox
ubuntu 18.04
### Logs
no specific log
no error log
Some new information
My owncloud server (with apache) is behind a front web server in nginx.
This nginx server apply a proxy pass to the apache.
And the problem seem’s link with this configuration.
When I connect directly to the apache server with “IP of owncloud”/owncloud the file larger than 2MB can be upload.
When I connect to owncloud.mydomain.com (which send to the front web server in nginx) the upload over 2MB does not work.
Any new idea to see where the upload is stucks…
It works !!!
I just have to add :
client_max_body_size 16G;
in the server configuration (owncloud.conf file in the site-enable of nginx)
nice that you got this to work. It seems this setting is even documented here:
https://doc.owncloud.org/server/administration_manual/configuration/files/big_file_upload_configuration.html
In which file should I add client_max_body_size 16G; ?
In the “/etc/nginx/sites-available/owncloud.conf”
in the server configuration :
server {
I know that post might by out dated but maybe someone like me will look for answer.
At my case - docker installation of owncloud - I had to specify
upload_tmp_dir = “/tmp”
sys_temp_dir = “/tmp”
in php.ini file located in
/etc/php/7.4/apache2/php.ini
