arlenn
March 16, 2017, 7:03am
1
I cannot seem to get OC 914 to work with Gmail SMTP. (which usually has gone really well for me).
selecting 465 I get the following error:
Error: Expected response code 250 but got code “”, with message “”
selecting 587:
Connection could not be established with host smtp.gmail.com [ #0 ])
This is both with “login” and “plain” I am quite sure I have the password correct.
Anybody seen this?
Any way to get a more verbose error message?
Thanks in advance.
If that worked before it might be the same as in [1] and [2]. A rule of thumb is that if something worked before and stopped to work in a newer a bug should be created at the bugtracker.
[1]
Hei, after owncloud upgrade 9.1.2 to 9.1.4 not working SMTP I give this error: A problem occurred while sending the email. Please revise your settings. (Error: Failed to authenticate on SMTP server with username "cuser@email.com" using 0 possible authenticators)
Any solution ?
I use: Ubuntu server 16.04.2 PHP version 7.1.2 Apache 2.4.25
[2]
opened 10:52AM - 07 Mar 17 UTC
closed 03:51PM - 18 Dec 17 UTC
Hei,
I give this error:…
Any solution ?
I use:
PHP version 5.6
Apache 2.4.25
arlenn
March 16, 2017, 7:16am
3
Thanks for the comment…
It worked in OC 8.n this a brand new install to 9.1.4… so this is looking like a bug/regression with 9.1.4, possibly?
Exactly as explained above and already reported by that other users to the developers.
