- Login to web-interface of ownCloud
- Select the share button of a random (non-shared) directory and select “public link” and click the “Create public link” button.
- The popup only shows the current directory name and no other fields/options. Hit the “share” button, nothing happens.
Public links created through desktop-client work without problems and also show up in the web-interface. In webinterface only thing possible is deletion of a public link. Edit, etc. doesn’t work in that case either!
Provide fields like “link name” and share button actually creating the link.
Nothing happens, nothing ends up in log of owncloud (loglevel 0) nor in php log (debug).
Operating system: CentOS 6
Web server: Apache 2.4.33
Database: MySQL 5.7
PHP version: 7.1.18
ownCloud version: (see ownCloud admin page) 10.0.8.5
Updated from an older ownCloud or fresh install: updated from 10.0.7
Where did you install ownCloud from: zip downloaded from owncloud.org
"system": {
"instanceid": "ocwchot38odu",
"trusted_domains": [
"cloud.hucon.pl"
"datadirectory": "\/home\/cloud\/domains\/cloud.hucon.pl\/cloud_data",
"overwrite.cli.url": "http:\/\/cloud.hucon.pl",
"dbtype": "mysql",
"version": "10.0.8.5",
"dbname": "cloud_cloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"logtimezone": "UTC",
"installed": true,
"mail_smtpmode": "php",
"theme": "",
"loglevel": 0,
"maintenance": false,
"memcache.local": "\\OC\\Memcache\\Redis",
"redis": {
"host": "localhost",
"port": 6379
"htaccess.RewriteBase": "\/",
"appstore.experimental.enabled": true,
"singleuser": false,
"session_keepalive": true,
"versions_retention_obligation": "auto, 60",
"operation.mode": "single-instance",
"enable_previews": true
Enabled:
- announcementcenter: 1.2.0
- audioplayer: 2.3.0
- checksum: 0.3.5
- configreport: 0.1.1
- dav: 0.3.2
- diagnostics: 0.1.2
- encryption: 1.3.1
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_pdfviewer: 0.8.2
- files_sharing: 0.10.1
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- gallery: 16.0.2
- impersonate: 0.2.0
- market: 0.2.4
- music: 0.6.1
- notifications: 0.3.3
- provisioning_api: 0.5.0
- updatenotification: 0.2.1
Disabled:
- comments
- external
- systemtags
- theme-example
- user_external
Are you using external storage, if yes which one: : no
Are you using encryption: yes
Are you using an external user-backend, if yes which one: LDAP/ActiveDirectory/Webdav/…: no
Browser: Chrome, Safari, FireFox – all have same issue.
Operating system: MacOS 10.13 and Windows 10 have been tested and both show.
no httpd errors
EMPTY
Javascript console:
jquery-migrate.min.js?v=e122f6801fca38f936dafa858c26fff3:2 JQMIGRATE: Migrate is installed, version 1.4.0
soundmanager2-jsmin.js?v=e122f6801fca38f936dafa858c26fff3:34 SoundManager V2.97a.20170601 (HTML5-only mode)
soundmanager2-jsmin.js?v=e122f6801fca38f936dafa858c26fff3:34 SoundManager 2 HTML5 support: mp3 = true, mp4 = true, ogg = true, opus = true, wav = true, flac = true
soundmanager2-jsmin.js?v=e122f6801fca38f936dafa858c26fff3:34 SoundManager 2: Ready. ✓
4js.js?v=e122f6801fca38f936dafa858c26fff3:2287 Deprecation warning: tipsy is deprecated. Use tooltip instead.
jQuery.fn.tipsy @ js.js?v=e122f6801fca38f936dafa858c26fff3:2287
markFileAsShared @ share.js?v=e122f6801fca38f936dafa858c26fff3:305
_updateFileActionIcon @ share.js?v=e122f6801fca38f936dafa858c26fff3:237
(anonymous) @ share.js?v=e122f6801fca38f936dafa858c26fff3:149
_.each._.forEach @ underscore.js?v=e122f6801fca38f936dafa858c26fff3:153
(anonymous) @ share.js?v=e122f6801fca38f936dafa858c26fff3:130
dispatch @ jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:3
r.handle @ jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:3
trigger @ jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:3
a.event.trigger @ jquery-migrate.min.js?v=e122f6801fca38f936dafa858c26fff3:2
(anonymous) @ jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:3
each @ jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:2
_nextPage @ filelist.js?v=e122f6801fca38f936dafa858c26fff3:963
setFiles @ filelist.js?v=e122f6801fca38f936dafa858c26fff3:1015
reloadCallback @ filelist.js?v=e122f6801fca38f936dafa858c26fff3:1651
(anonymous) @ jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:2
j @ jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:2
fireWith @ jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:2
e.(anonymous function) @ jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:2
(anonymous) @ client.js?v=e122f6801fca38f936dafa858c26fff3:476
Promise.then (async)
getFolderContents @ client.js?v=e122f6801fca38f936dafa858c26fff3:469
reload @ filelist.js?v=e122f6801fca38f936dafa858c26fff3:1570
changeDirectory @ filelist.js?v=e122f6801fca38f936dafa858c26fff3:1430
_onUrlChanged @ filelist.js?v=e122f6801fca38f936dafa858c26fff3:560
_onPopState @ app.js?v=e122f6801fca38f936dafa858c26fff3:276
initialize @ app.js?v=e122f6801fca38f936dafa858c26fff3:110
(anonymous) @ app.js?v=e122f6801fca38f936dafa858c26fff3:317
(anonymous) @ underscore.js?v=e122f6801fca38f936dafa858c26fff3:768
setTimeout (async)
_.delay @ underscore.js?v=e122f6801fca38f936dafa858c26fff3:767
executeBound @ underscore.js?v=e122f6801fca38f936dafa858c26fff3:701
bound @ underscore.js?v=e122f6801fca38f936dafa858c26fff3:733
(anonymous) @ app.js?v=e122f6801fca38f936dafa858c26fff3:316
ready @ jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:2
I @ jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:2
sharedialogmailview.js?v=e122f6801fca38f936dafa858c26fff3:197 Uncaught TypeError: this.$el.find(...).select2 is not a function
at child._afterRender (sharedialogmailview.js?v=e122f6801fca38f936dafa858c26fff3:197)
at child.<anonymous> (sharedialogmailview.js?v=e122f6801fca38f936dafa858c26fff3:62)
at executeBound (underscore.js?v=e122f6801fca38f936dafa858c26fff3:701)
at child.bound [as render] (underscore.js?v=e122f6801fca38f936dafa858c26fff3:733)
at child.render (sharedialoglinkshareview.js?v=e122f6801fca38f936dafa858c26fff3:270)
at Object.adjustDialog (sharedialoglinkshareview.js?v=e122f6801fca38f936dafa858c26fff3:367)
at Object.<anonymous> (jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:2)
at j (jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:2)
at Object.fireWith [as resolveWith] (jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:2)
_afterRender @ sharedialogmailview.js?v=e122f6801fca38f936dafa858c26fff3:197
(anonymous) @ sharedialogmailview.js?v=e122f6801fca38f936dafa858c26fff3:62
render @ sharedialoglinkshareview.js?v=e122f6801fca38f936dafa858c26fff3:270
adjustDialog @ sharedialoglinkshareview.js?v=e122f6801fca38f936dafa858c26fff3:367
(anonymous) @ oc-dialogs.js?v=e122f6801fca38f936dafa858c26fff3:710
x @ jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:4
(anonymous) @ jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:4
load (async)
send @ jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:4
ajax @ jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:4
n.(anonymous function) @ jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:4
_getMessageTemplate @ oc-dialogs.js?v=e122f6801fca38f936dafa858c26fff3:708
message @ oc-dialogs.js?v=e122f6801fca38f936dafa858c26fff3:246
show @ sharedialoglinkshareview.js?v=e122f6801fca38f936dafa858c26fff3:357
_showPopupForShare @ sharedialoglinklistview.js?v=e122f6801fca38f936dafa858c26fff3:211
onAddButtonClick @ sharedialoglinklistview.js?v=e122f6801fca38f936dafa858c26fff3:157
8sharedialogexpirationview.js?v=e122f6801fca38f936dafa858c26fff3:159 Uncaught TypeError: Cannot read property 'val' of undefined
at child.getValue (sharedialogexpirationview.js?v=e122f6801fca38f936dafa858c26fff3:159)
at child._save (sharedialoglinkshareview.js?v=e122f6801fca38f936dafa858c26fff3:129)
at child._onClickSave (sharedialoglinkshareview.js?v=e122f6801fca38f936dafa858c26fff3:300)
at HTMLButtonElement.<anonymous> (jquery.ocdialog.js?v=e122f6801fca38f936dafa858c26fff3:108)
at HTMLButtonElement.dispatch (jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:3)
at HTMLButtonElement.r.handle (jquery.min.js?v=e122f6801fca38f936dafa858c26fff3:3)
getValue @ sharedialogexpirationview.js?v=e122f6801fca38f936dafa858c26fff3:159
_save @ sharedialoglinkshareview.js?v=e122f6801fca38f936dafa858c26fff3:129
_onClickSave @ sharedialoglinkshareview.js?v=e122f6801fca38f936dafa858c26fff3:300
(anonymous) @ jquery.ocdialog.js?v=e122f6801fca38f936dafa858c26fff3:108
