i will share a folder Test as public link via e-mail. I fill the orm correctly and paste my e-mail in the field
Send Link as E-Mail
and press Enter. The E-Mail address are correctly (i have tested the mail wiht the admin, put this mail-address in the admin’s E-Mail and send a Test Message, this are working propertly) After That i putted a short Message in the Message Field and click
Share
the system displays this error
(in German Beim Versenden der E-Mail ist ein Fehler aufgetreten ) An error occurred while sending the e-mail
(a black symbol) and then {message}
no entry found in the logfile
Alright, your upgrade went fine ? No integrity check errors ?
What’s your mail configuration ? Is it sent through your local mail server such as postfix or is it an external SMTP ?
The upgrade is complete without any errors, the mail server is a external exchange connector. I have send a test mail to the same recpient, to whom I also want to send the link. The testmail are successfully recieved
Thanks for your answer, could you try changing the logging level to INFO or DEBUG, and retry the share ?
Could you also try using this service http://www.mail-tester.com/?lang=en ? You just have to share a file or anything (something you don’t care much for privacy’ sake) with the mail shown on the mail-tester.com and check afterwards. If it receives nothing then there is really a problem with public link via e-mail.
the loglevel is at the moment set to zero (debug) when i shared via public link and send a mail to the addess in mail-tester, i become no answer. The link are created, bur no mail was sending. In the log-file, no error message was displayed
Well that’s odd, does the recipient mail has an hyphen ? I found that bug but it seems solved. Since mail-tester has one too, it could be a correct hint.
EDIT: not sure it’s relevant since it should be solved and that the problem E-Mail addresses with “-” charakter in the second subdomain but still I’d try to send an email to some disposable email like yopmail.
EDIT2: could it be your exchange that blocks the mail for bad filtering (SPAM for example). Does your sending email exists ? If so can you check you don’t have a mailer daemon ?
the problem is very frustrated. I have create a user with my company mail address. Owncloud send me a user creating mail. Then i shared the same folder in private mode with send a notification to the user and also this was recieved, but when i edit the public link to add a mailadress, the described error was displayed. I have nothing idea, who ist error
the option was activated in Admin->share->public share->allow user to share links via e-mail. When this option are selected, you have the mail field in the sharing form
do you have a postfix or any SMTP on your machine hosting the ownCloud ? If yes, could you try changing your mail configuration to send through your local SMTP ? Thus you would know if it’s a matter with your Exchange or not.
we have not installed any SMTP services on the machine, all other mail functions are good, but only this one not function. I Think, is not the mail send function, rather then the form or the output generator are not correct. The error message is like microsoft-style all can not must
