i want to move my contacts and calendar from google to my owncloud.
on my desktop i use thunderbird.
do anyone have good recommendations for what to look out for -
and what thunderbird plugins to use?
i have found TBSync and SoGo.
but did not find any real info on what is the more used way - or if there are any drawbacks with one of theme…
at least when i have defined the calendars in the cloud first…
i will have to check how to sync the currently -local only- calendars…
additionally i have to check if it is possible to sync contacts from the CardBook AddressBook addon…
(default is to sync into the internal addressbook…)
