Storage not available for pre authorised
  1. Login to Owncloud
  2. Select Pre Configured Share (External Storage, SMB / CIFS, Username and Password)
    3.Storage Not available error message (Followed instructions found ownCloud 9.1.1: "Storage not available" - #7 by jpstaub results in new error message:
    Some of the configured external mount points are not connected. Please click on the red row(s) for more information
Should use entered creds to login to shared directory. It used to to this and now simply refuses to. The other share that uses Log-in credentials, save in session continues to work fine though.
Error messages: Some of the configured external mount points are not connected. Please click on the red row(s) for more information
OS: Ubuntu 16.04 LTS
WebServer: Apache2.4.18(ubuntu
Database: MYSql
Php -ver: 7
OwnCloud: 9.1.5 Updated from 9.1.1 I think?
Where did you install ownCloud from: Digital Ocean Instructions
https://gist.github.com/anonymous/d408f889fa7680be64f02dbb99a30284#file-not-important-but-anyway
https://gist.github.com/anonymous/87c44ee50b91077f71e3be6e589f7220
Are you using external storage, if yes which one:
SMB / CIFS
Are you using encryptio: no
Are you using an external user-backend, if yes which one:LDAP
can you access the share with the entered credentials? Outside of owncloud
Clicking in the red row should give you more information about what’s happening. Logs should also help.
If the password (or the credentials) changed you’ll need to enter the new ones. In addition, make sure the account you’re using isn’t locked by any other service.
