Hi, I’m using Owncloud 10. I’m not able to logging into the system the button to submit the username and password looks disable, it doesn’t do anything.
I got this in the Browser inspector.
Content Security Policy: The page’s settings blocked the loading of a resource at https://ajax.cloudflare.com/cdn-cgi/scripts/2448a7bd/cloudflare-static/rocket-loader.min.js (“script-src”).
Thank you in advance.
I think you have to tell us more about your system.
OS: Debian GNU/Linux testing (buster).
The button submit button doesn’t work at all.
For example I put my username & password but when I click it nothing happen
I mean answers to questions like:
Where did you get the owncloud package from?
How did you install?
Usually you have to fill-out an issue template, that is presented when opening a new topic.
this had ringed some bells for me and i did the following search:
https://central.owncloud.org/search?q=cloudflare%20login
which had lead to various threads which seems to suggest to disable cloudflare as it has caused these issues:
I had a similar problem recently, after turning on CloudFlare for my wordpress website. CF does some optimization to the code that is not compatible with OC login web page. I can't remember exactly what I did, but basically I turned off all CF optimization switches one by one, until I found the problematic one. That did the trick for me.
This is known to be caused by e.g. Cloudflare and other services or webserver modules messing around with the javascript used on the login page.
