On my own shared server webspace the /data-directory is alway bigger than the synced “equivalent” on my local drive: 170 to 120 GB. When I browse the /data-directory with my providers statistic tool I can see a plenty of directories that probably have existed somewhen, but then have gotten deleted or at least moved.
So: I am not talking of the GB the trash bin or the versions-folder ist taking!
Does anyone know how to solve that problem?
Thanks for a link or so, I cant imagine I am the first one, but couldn’t finde something else )-;
Operating system: os x
Web server: apache I think. Its a pretty standard provider!
ownCloud 8.2.9 (stable)
mhh…yummie…here is eventually why: I just realice there is a 27 MB-Logfile (since Sept. 2015). The last 40% show this type of error:
[code]{“reqId”:“WIpnslUNgA4AAHTc4XUAAAAF”,“remoteAddr”:“12.12.123.456”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 423 \"\u00d6A MT16\/__Pressespiegel\/_print\/2016_09_06_Dithmarscher_Landeszeitung.tiff\" is locked","Exception":"OC\\Connector\\Sabre\\Exception\\FileLocked","Code":0,"Trace":"#0 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Tree.php(179): OC\\Connector\\Sabre\\File->delete()\n#1 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(287): Sabre\\DAV\\Tree->delete(‘\\xC3\\x96A MT16\/__Pres…’)\n#2 [internal function]: Sabre\\DAV\\CorePlugin->httpDelete(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#3 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#4 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(469): Sabre\\Event\\EventEmitter->emit(‘method:DELETE’, Array)\n#5 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#6 \/www\/htdocs\/swswsws\/xxxxx.com\/apps\/files\/appinfo\/remote.php(56): Sabre\\DAV\\Server->exec()\n#7 \/www\/htdocs\/swswsws\/xxxxx.com\/remote.php(137): require_once(‘\/www\/htdocs\/w01…’)\n#8 {main}","File":"\/www\/htdocs\/swswsws\/xxxxx.com\/lib\/private\/connector\/sabre\/file.php","Line":320}”,“level”:4,“time”:“2017-01-26T22:18:42+01:00”}
{“reqId”:“WIpn@VUNgA4AAA6YSJ0AAAAB”,“remoteAddr”:“12.12.123.456”,“app”:“PHP”,“message”:“opendir(/tmp): failed to open dir: Permission denied at /www/htdocs/swswsws/xxxxx.com/lib/private/tempmanager.php#186”,“level”:3,“time”:“2017-01-26T22:19:53+01:00”}
{“reqId”:“WIpoBVUNgA4AAAwCOvMAAAAH”,“remoteAddr”:“12.12.123.456”,“app”:“PHP”,“message”:“opendir(/tmp): failed to open dir: Permission denied at /www/htdocs/swswsws/xxxxx.com/lib/private/tempmanager.php#186”,“level”:3,“time”:“2017-01-26T22:20:05+01:00”}
{“reqId”:“WIpoB1UNgA4AAHzwAC8AAAAG”,“remoteAddr”:“12.12.123.456”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 423 \"\u00d6A MT16\/__Pressespiegel\/_print\/2016_09_03_Nordwest_Zeitung_Wesermarsch_Zeitung.tiff\" is locked","Exception":"OC\\Connector\\Sabre\\Exception\\FileLocked","Code":0,"Trace":"#0 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Tree.php(179): OC\\Connector\\Sabre\\File->delete()\n#1 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(287): Sabre\\DAV\\Tree->delete(‘\\xC3\\x96A MT16\/__Pres…’)\n#2 [internal function]: Sabre\\DAV\\CorePlugin->httpDelete(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#3 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#4 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(469): Sabre\\Event\\EventEmitter->emit(‘method:DELETE’, Array)\n#5 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#6 \/www\/htdocs\/swswsws\/xxxxx.com\/apps\/files\/appinfo\/remote.php(56): Sabre\\DAV\\Server->exec()\n#7 \/www\/htdocs\/swswsws\/xxxxx.com\/remote.php(137): require_once(‘\/www\/htdocs\/w01…’)\n#8 {main}","File":"\/www\/htdocs\/swswsws\/xxxxx.com\/lib\/private\/connector\/sabre\/file.php","Line":320}”,“level”:4,“time”:“2017-01-26T22:20:07+01:00”}
{“reqId”:“WIpoB1UNgA4AAHzwADAAAAAG”,“remoteAddr”:“12.12.123.456”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 423 \"\u00d6A MT16\/__Pressespiegel\/_print\/2016_09_03_blickpunkt_zum_sonntag_Landkreis_Nienburg.tiff\" is locked","Exception":"OC\\Connector\\Sabre\\Exception\\FileLocked","Code":0,"Trace":"#0 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Tree.php(179): OC\\Connector\\Sabre\\File->delete()\n#1 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(287): Sabre\\DAV\\Tree->delete(‘\\xC3\\x96A MT16\/__Pres…’)\n#2 [internal function]: Sabre\\DAV\\CorePlugin->httpDelete(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#3 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#4 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(469): Sabre\\Event\\EventEmitter->emit(‘method:DELETE’, Array)\n#5 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#6 \/www\/htdocs\/swswsws\/xxxxx.com\/apps\/files\/appinfo\/remote.php(56): Sabre\\DAV\\Server->exec()\n#7 \/www\/htdocs\/swswsws\/xxxxx.com\/remote.php(137): require_once(‘\/www\/htdocs\/w01…’)\n#8 {main}","File":"\/www\/htdocs\/swswsws\/xxxxx.com\/lib\/private\/connector\/sabre\/file.php","Line":320}”,“level”:4,“time”:“2017-01-26T22:20:07+01:00”}
{“reqId”:“WIpoCFUNgA4AABo4VUcAAAAB”,“remoteAddr”:“12.12.123.456”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 423 \"\u00d6A MT16\/__Pressespiegel\/_print\/2016_09_03_Wilhelmshavener_Zeitung.tiff\" is locked","Exception":"OC\\Connector\\Sabre\\Exception\\FileLocked","Code":0,"Trace":"#0 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Tree.php(179): OC\\Connector\\Sabre\\File->delete()\n#1 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(287): Sabre\\DAV\\Tree->delete(‘\\xC3\\x96A MT16\/__Pres…’)\n#2 [internal function]: Sabre\\DAV\\CorePlugin->httpDelete(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#3 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#4 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(469): Sabre\\Event\\EventEmitter->emit(‘method:DELETE’, Array)\n#5 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#6 \/www\/htdocs\/swswsws\/xxxxx.com\/apps\/files\/appinfo\/remote.php(56): Sabre\\DAV\\Server->exec()\n#7 \/www\/htdocs\/swswsws\/xxxxx.com\/remote.php(137): require_once(‘\/www\/htdocs\/w01…’)\n#8 {main}","File":"\/www\/htdocs\/swswsws\/xxxxx.com\/lib\/private\/connector\/sabre\/file.php","Line":320}”,“level”:4,“time”:“2017-01-26T22:20:08+01:00”}
{“reqId”:“WIpoCFUNgA4AABo5VigAAAAD”,“remoteAddr”:“12.12.123.456”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 423 \"\u00d6A MT16\/__Pressespiegel\/_print\/2016_09_06_Nordwest-Zeitung_Wesermarsch-Zeitung.tiff\" is locked","Exception":"OC\\Connector\\Sabre\\Exception\\FileLocked","Code":0,"Trace":"#0 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Tree.php(179): OC\\Connector\\Sabre\\File->delete()\n#1 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(287): Sabre\\DAV\\Tree->delete(‘\\xC3\\x96A MT16\/__Pres…’)\n#2 [internal function]: Sabre\\DAV\\CorePlugin->httpDelete(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#3 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#4 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(469): Sabre\\Event\\EventEmitter->emit(‘method:DELETE’, Array)\n#5 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#6 \/www\/htdocs\/swswsws\/xxxxx.com\/apps\/files\/appinfo\/remote.php(56): Sabre\\DAV\\Server->exec()\n#7 \/www\/htdocs\/swswsws\/xxxxx.com\/remote.php(137): require_once(‘\/www\/htdocs\/w01…’)\n#8 {main}","File":"\/www\/htdocs\/swswsws\/xxxxx.com\/lib\/private\/connector\/sabre\/file.php","Line":320}”,“level”:4,“time”:“2017-01-26T22:20:09+01:00”}
{“reqId”:“WIpoCFUNgA4AABo4VUgAAAAB”,“remoteAddr”:“12.12.123.456”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 423 \"\u00d6A MT16\/__Pressespiegel\/_print\/2016_09_06_Dithmarscher_Landeszeitung.tiff\" is locked","Exception":"OC\\Connector\\Sabre\\Exception\\FileLocked","Code":0,"Trace":"#0 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Tree.php(179): OC\\Connector\\Sabre\\File->delete()\n#1 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(287): Sabre\\DAV\\Tree->delete(‘\\xC3\\x96A MT16\/__Pres…’)\n#2 [internal function]: Sabre\\DAV\\CorePlugin->httpDelete(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#3 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#4 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(469): Sabre\\Event\\EventEmitter->emit(‘method:DELETE’, Array)\n#5 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#6 \/www\/htdocs\/swswsws\/xxxxx.com\/apps\/files\/appinfo\/remote.php(56): Sabre\\DAV\\Server->exec()\n#7 \/www\/htdocs\/swswsws\/xxxxx.com\/remote.php(137): require_once(‘\/www\/htdocs\/w01…’)\n#8 {main}","File":"\/www\/htdocs\/swswsws\/xxxxx.com\/lib\/private\/connector\/sabre\/file.php","Line":320}”,“level”:4,“time”:“2017-01-26T22:20:09+01:00”}
{“reqId”:“WIpoW1UNgA4AACWOEaMAAAAW”,“remoteAddr”:“12.12.123.456”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 423 \"\u00d6A MT16\/__Pressespiegel\/_print\/2016_09_03_Nordwest_Zeitung_Wesermarsch_Zeitung.tiff\" is locked","Exception":"OC\\Connector\\Sabre\\Exception\\FileLocked","Code":0,"Trace":"#0 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Tree.php(179): OC\\Connector\\Sabre\\File->delete()\n#1 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(287): Sabre\\DAV\\Tree->delete(‘\\xC3\\x96A MT16\/__Pres…’)\n#2 [internal function]: Sabre\\DAV\\CorePlugin->httpDelete(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#3 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#4 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(469): Sabre\\Event\\EventEmitter->emit(‘method:DELETE’, Array)\n#5 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#6 \/www\/htdocs\/swswsws\/xxxxx.com\/apps\/files\/appinfo\/remote.php(56): Sabre\\DAV\\Server->exec()\n#7 \/www\/htdocs\/swswsws\/xxxxx.com\/remote.php(137): require_once(‘\/www\/htdocs\/w01…’)\n#8 {main}","File":"\/www\/htdocs\/swswsws\/xxxxx.com\/lib\/private\/connector\/sabre\/file.php","Line":320}”,“level”:4,“time”:“2017-01-26T22:21:31+01:00”}
{“reqId”:“WIpoW1UNgA4AACWSE3oAAAAa”,“remoteAddr”:“12.12.123.456”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 423 \"\u00d6A MT16\/__Pressespiegel\/_print\/2016_09_06_Dithmarscher_Landeszeitung.tiff\" is locked","Exception":"OC\\Connector\\Sabre\\Exception\\FileLocked","Code":0,"Trace":"#0 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Tree.php(179): OC\\Connector\\Sabre\\File->delete()\n#1 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(287): Sabre\\DAV\\Tree->delete(‘\\xC3\\x96A MT16\/__Pres…’)\n#2 [internal function]: Sabre\\DAV\\CorePlugin->httpDelete(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#3 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#4 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(469): Sabre\\Event\\EventEmitter->emit(‘method:DELETE’, Array)\n#5 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#6 \/www\/htdocs\/swswsws\/xxxxx.com\/apps\/files\/appinfo\/remote.php(56): Sabre\\DAV\\Server->exec()\n#7 \/www\/htdocs\/swswsws\/xxxxx.com\/remote.php(137): require_once(‘\/www\/htdocs\/w01…’)\n#8 {main}","File":"\/www\/htdocs\/swswsws\/xxxxx.com\/lib\/private\/connector\/sabre\/file.php","Line":320}”,“level”:4,“time”:“2017-01-26T22:21:31+01:00”}
{“reqId”:“WIpoW1UNgA4AACWREwsAAAAZ”,“remoteAddr”:“12.12.123.456”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 423 \"\u00d6A MT16\/__Pressespiegel\/_print\/2016_09_06_Nordwest-Zeitung_Wesermarsch-Zeitung.tiff\" is locked","Exception":"OC\\Connector\\Sabre\\Exception\\FileLocked","Code":0,"Trace":"#0 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Tree.php(179): OC\\Connector\\Sabre\\File->delete()\n#1 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(287): Sabre\\DAV\\Tree->delete(‘\\xC3\\x96A MT16\/__Pres…’)\n#2 [internal function]: Sabre\\DAV\\CorePlugin->httpDelete(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#3 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#4 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(469): Sabre\\Event\\EventEmitter->emit(‘method:DELETE’, Array)\n#5 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#6 \/www\/htdocs\/swswsws\/xxxxx.com\/apps\/files\/appinfo\/remote.php(56): Sabre\\DAV\\Server->exec()\n#7 \/www\/htdocs\/swswsws\/xxxxx.com\/remote.php(137): require_once(‘\/www\/htdocs\/w01…’)\n#8 {main}","File":"\/www\/htdocs\/swswsws\/xxxxx.com\/lib\/private\/connector\/sabre\/file.php","Line":320}”,“level”:4,“time”:“2017-01-26T22:21:31+01:00”}
{“reqId”:“WIpoW1UNgA4AACWQEpkAAAAY”,“remoteAddr”:“12.12.123.456”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 423 \"\u00d6A MT16\/__Pressespiegel\/_print\/2016_09_03_Wilhelmshavener_Zeitung.tiff\" is locked","Exception":"OC\\Connector\\Sabre\\Exception\\FileLocked","Code":0,"Trace":"#0 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Tree.php(179): OC\\Connector\\Sabre\\File->delete()\n#1 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(287): Sabre\\DAV\\Tree->delete(‘\\xC3\\x96A MT16\/__Pres…’)\n#2 [internal function]: Sabre\\DAV\\CorePlugin->httpDelete(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#3 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#4 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(469): Sabre\\Event\\EventEmitter->emit(‘method:DELETE’, Array)\n#5 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#6 \/www\/htdocs\/swswsws\/xxxxx.com\/apps\/files\/appinfo\/remote.php(56): Sabre\\DAV\\Server->exec()\n#7 \/www\/htdocs\/swswsws\/xxxxx.com\/remote.php(137): require_once(‘\/www\/htdocs\/w01…’)\n#8 {main}","File":"\/www\/htdocs\/swswsws\/xxxxx.com\/lib\/private\/connector\/sabre\/file.php","Line":320}”,“level”:4,“time”:“2017-01-26T22:21:31+01:00”}
{“reqId”:“WIpoW1UNgA4AACWTE@UAAAAb”,“remoteAddr”:“12.12.123.456”,“app”:“webdav”,“message”:“Exception: {"Message":"HTTP\/1.1 423 \"\u00d6A MT16\/__Pressespiegel\/_print\/2016_09_03_blickpunkt_zum_sonntag_Landkreis_Nienburg.tiff\" is locked","Exception":"OC\\Connector\\Sabre\\Exception\\FileLocked","Code":0,"Trace":"#0 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Tree.php(179): OC\\Connector\\Sabre\\File->delete()\n#1 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php(287): Sabre\\DAV\\Tree->delete(‘\\xC3\\x96A MT16\/__Pres…’)\n#2 [internal function]: Sabre\\DAV\\CorePlugin->httpDelete(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#3 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#4 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(469): Sabre\\Event\\EventEmitter->emit(‘method:DELETE’, Array)\n#5 \/www\/htdocs\/swswsws\/xxxxx.com\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#6 \/www\/htdocs\/swswsws\/xxxxx.com\/apps\/files\/appinfo\/remote.php(56): Sabre\\DAV\\Server->exec()\n#7 \/www\/htdocs\/swswsws\/xxxxx.com\/remote.php(137): require_once(‘\/www\/htdocs\/w01…’)\n#8 {main}","File":"\/www\/htdocs\/swswsws\/xxxxx.com\/lib\/private\/connector\/sabre\/file.php","Line":320}”,“level”:4,“time”:“2017-01-26T22:21:31+01:00”}
{“reqId”:“WIp5eVUNgA4AAFUx1XgAAAAA”,“remoteAddr”:“12.12.123.456”,“app”:“PHP”,“message”:“opendir(/tmp): failed to open dir: Permission denied at /www/htdocs/swswsws/xxxxx.com/lib/private/tempmanager.php#186”,“level”:3,“time”:“2017-01-26T23:34:33+01:00”}
[/code]
Integrity status for oC9+
-> doenst work, it sends me to "files"
