Trusted domains
I want to install owncloud on a real server, but from a remote machine.
I did everything but when I connect to the web interface I receive this error message :
“Vous accédez au serveur à partir d’un domaine non approuvé.
Please contact your administrator. If you are an administrator of this instance, configure the “trusted_domains” setting in config/config.php. An example configuration is provided in config/config.sample.php or at the documentation.”
-PS: my file “config.php” is edited like this :
‘trusted_domains’ => [
0 => ‘localhost’,
1 => ‘server1.example.com’,
2 => ‘91.121.XXX.XXX’, (XXX.XXX is the continuation of my IP address)
thank you for helping me
The entry in the config.php itself should be in the following format:
'trusted_domains' =>
  array (
    0 => 'localhost',
   1 => '91.121.XXX.XXX',
The IP Address “91.121.XXX.XXX” is what you enter in your browser when you try to access your owncloud server.
If you type in something else, you should adjust the entry in the config.php.
You can look in the owncloud.log for more information.
The logfile is in /var/www/owncloud/data/owncloud.log
I still have the same problem :disappointed:
In Order to help you I need more information
I will install Owncloud on a Serveur with remote control with “putty”.
I followed the script you posted on a “wath is my server” response.
I executed the script, Owncloud is installed successfully but when I connect to the Owncloud web interface (IPaddServer/Owncloud) there is this message that appears :
What is the OS of your remote server?
What is the IP of your remote server?
Did you install ownCloud directly on the server or in a VM?
What is your config.php looks like?
What is the output of your servers ipconfig or ifconfig?
what is the output of the owncloud server “hostname -I”?
If you want your problem resolved you have to provide information, that’s what the form is for, that you have to fill out when opening a new Topic in this forum. Without the information we poke blindly in an unspecified direction.
I found the solution, you have to access to /var/www/owncloud then you have to edit conf.php, we must add the address IP of server !
Thank u so mush Dmitry :v:
Glad I could help you out. Have fun with ownCloud
@DABAJ_Anass Yes! Exacly!!! That is the full solution.
First to add IP address what you enter in your web browser when trying to access owncloud server inside file:
/var/www/owncloud/config/config.php
array (
0 => ‘localhost’,
1 => ‘192.168.0.1’,
2 => ‘owncloud-server-machine-name’,
And then your client host IP addres inside:
/var/www/html/owncloud/config/config.php
array (
0 => ‘localhost’,
1 => ‘owncloud-server-machine’,
2 => ‘192.168.0.1’,
3 => ‘192.168.0.2’,
And then it will works!
I too have the same problem.
I have hosted the owncloud on webhosting. How which IP I must config in config.php?? My ISP IP?? or my local IP of computer obtained from modem/router? or my domain name IP ?
Please suggest.
The IP of the server on which ownCloud runs.
I would not add the external ip of the server
I only have local ip and fqdn
I added the IP Address of server.
Now I am able to open by owncloud.domainname and not by domainname/owncloud/
Now also domainname/owncloud/ displays the error of trusted domains.
Please suggest.
I tried opening on different machine by owncloud.domainname, then this also shows me trusted domains error.
Please suggest some permanent solution for this?
How about entering the owncloud.domainname in the trusted domain name array? without the “https://” just the domain name.
IMO the logic behind trusted domain is to prevent people accessing the cloud from using an external ip.
I see it as a security risk .
Local ip and fqdn is safer
i have used the first URL and this works and i don’t get an trusted domains error.
I have entered first url only in config.php file of owncloud.
I am surprised how this all is happening.
I open from 1 PC, it is opening. I tried from another it is not.
You conveyed me it is not giving me error whereas now also It is giving me trusted domains error if i try opening using mobile internet connection.
Why this is all happening?
What do you put in the address bar when you sccceded and when you fail ?
Nice pic, but what do you want to tell us with this?
