Unlimited loading
I am just starting to use OwnCloud and when I go to the main menu where I should have my files, I have unlimited loading and unable to upload any file. Namely that there is no file already present, and that due to the loading, I cannot add a file either.
When I look at the console it is noted this following error:
Failed to load resource: the server responded with a status of 501 ()
Uncaught (in promise) TypeError: Cannot read property ‘getElementsByTagNameNS’ of null
at Client._getSabreException (client.js?v=551b3844162d44e93382c25e8c5bd0da:430)
at client.js?v=551b3844162d44e93382c25e8c5bd0da:494
Could you help me please ?
Thanks in advance.
Regards.
D.F
Hi Flavien,
unfortunately this is too little information, with the Error you provided, we cannot even guess.
There was an issue template when you started the topic. This is there for the good reason that without knowlege of configuration, logs etc. it is almost impossible to track down errors. Especially the owncloud.log gives information, why the 501 happened with your call.
For your convenience, here are the most important parts from the issue template again:
I didn’t find the first part, srry.
Version ownCloud 10.4.1 (stable)
Installed from ownCloud
Apps: Image 1
I don’t know for the next questions
I don’t find the owncloud logs
Here are Browser logs ;
    JQMIGRATE: Migrate is installed, version 1.4.0
l10n.js?v=551b3844162d44e93382c25e8c5bd0da:99 Missing plural form in language file
_generatePluralFunction @ l10n.js?v=551b3844162d44e93382c25e8c5bd0da:99
js.js?v=551b3844162d44e93382c25e8c5bd0da:2311 Deprecation warning: tipsy is deprecated. Use tooltip instead.
jQuery.fn.tipsy @ js.js?v=551b3844162d44e93382c25e8c5bd0da:2311
/remote.php/dav/files/FlavienDev/:1 Failed to load resource: the server responded with a status of 501 (Not Implemented)
client.js?v=551b3844162d44e93382c25e8c5bd0da:430 Uncaught (in promise) TypeError: Cannot read property 'getElementsByTagNameNS' of null
cloud.delvauxflavien.fr/:1 Unchecked runtime.lastError: The message port closed before a response was received.
fsUtils.js:11
Hope you will find the problem !
D.F
Apps : Image 2
i think this could be the reason for your problem. I did a search like Search results for '"501" "Not Implemented"' - ownCloud Central and found a few existing threads which i think could help to configure your web server correctly for ownCloud:
