Update from 10.1.1.1 to 10.3.2 failed. No sudo in shell... 1and1 - Advice needed!
Hi there,
First of all, let me say I love Owncloud and have been using it regularly and it has been so useful to me over the years and I thank all the contributors!
Having never had any problems in the past I bravely / foolishly clicked upgrade in my OC web interface without checking any of the pages about the procedure of precautions to take before hand. I know, I know, I don’t deserve any help… !
I would like to know if there is a way of fixing this mess using ftp and/or basic ssh access. I can’t run occ unfortunately as I don’t seem to have appropriate privileges on this server so this is preventing me from following the standard procedure. Otherwise, if someone can at least confirm that I’m out of luck, then I will give up on trying to fix things and create a new install.
Maybe all I need to do is disable the addon that seems to be causing the problem. Is there a way of doing this via ssh / ftp without sudo?
Thanks for your help.
I used the web interface to initiate an update. Several of the steps completed successfully but then the installation went into maintenance mode. After waiting a few hours, I connected via SSH and set maintenance to false in config.php.
Update owncloud
Updating to 10.3.2
Repair warning: You have incompatible or missing apps enabled that could not be found or updated via the marketplace.
Repair warning: Please install or update the following apps manually or disable them with: occ app:disable drawio
Repair warning: For manually updating, see https://doc.owncloud.org/server/10.3/go.php?to=admin-marketplace-apps
Detailed logs ![](https://preid.org/cloud/core/img/actions/caret.svg)
Preparing update
Set log level to debug
Turned on maintenance mode
The update was unsuccessful. Please report this issue to the [ownCloud community](https://github.com/owncloud/core/issues).
Debian 8
Apache
sqlite
10.1.1.1
Updated
I dropped some files into my ftp and installed using the web interface a few years back. I have been updating periodically since.
Not sure what this means. My domain has a certificate for SSL. The URL starts with “https”
I Can’t currently log in unfortunately.
I can't login to owncloud or run sudo unfortunately at the moment.
    <?php
    $CONFIG = array (
      'dbtype' => 'sqlite3',
      'version' => '10.1.1.1',
      'logtimezone' => 'UTC',
      'installed' => true,
      'mail_from_address' => 'cloud',
      'mail_smtpmode' => 'php',
      'loglevel' => 2,
      'maintenance' => false,
      'theme' => '',
no
not sure. I have https, otherwise I expect the answer is no.
Not sure. I’m guessing not. I use the desktop client if that is relevant.
No sudo...
I don't really understand what this is asking and I don't have sql installed locally. (yet!)
Firefox
MacOS 10.14.6
Not sure I can access this.
This is a very big file ~700MB, I don't know whether I should really post it and there seems to be alot of sensitive info in it...
edit: I just found the following update.log file.  It looks like the updater updated incrementally from 9.1.3.1 forward until 10.1.1.1 where it got as far as it was going to go.  It doesn't look like there were any errors along the way...  This log was last modified at the time of the last update (unsurprisingly) but was created 2001-01-01 so maybe it dates from when I first started using the integrated updater...
update.log
    [info] Execution of upgrade:detect command started
[info] ownCloud 9.1.3.1 found
[info] Execution of upgrade:detect command stopped. Exit code is 0
[info] Execution of upgrade:checkpoint command started
[info] Execution of upgrade:checkpoint command stopped. Exit code is 0
[info] Execution of upgrade:checkSystem command started
[info] Execution of upgrade:checkSystem command stopped. Exit code is 0
[info] Execution of upgrade:disableNotShippedApps command started
[info] Execution of upgrade:disableNotShippedApps command stopped. Exit code is 0
[info] Execution of upgrade:executeCoreUpgradeScripts command started
[debug] Replacing 3rdparty
[debug] Replacing config
[debug] Replacing core
[debug] Replacing l10n
[debug] Replacing lib
[debug] Replacing ocs
[debug] Replacing ocs-provider
[debug] Replacing resources
[debug] Replacing settings
[debug] Replacing .htaccess
[debug] Replacing .mailmap
[debug] Replacing .tag
[debug] Replacing .user.ini
[debug] Replacing AUTHORS
[debug] Replacing console.php
[debug] Replacing COPYING-AGPL
[debug] Replacing cron.php
[debug] Replacing db_structure.xml
[debug] Replacing index.html
[debug] Replacing index.php
[debug] Replacing indie.json
[debug] Replacing occ
[debug] Replacing public.php
[debug] Replacing remote.php
[debug] Replacing robots.txt
[debug] Replacing status.php
[debug] Replacing version.php
[info] Execution of upgrade:executeCoreUpgradeScripts command stopped. Exit code is 0
[info] Execution of upgrade:enableNotShippedApps command started
[info] Execution of upgrade:enableNotShippedApps command stopped. Exit code is 0
[info] Execution of upgrade:restartWebServer command started
[info] Execution of upgrade:restartWebServer command stopped. Exit code is 0
[info] Execution of upgrade:postUpgradeCleanup command started
[debug] Moving updater/app
[debug] Moving updater/application.php
[debug] Moving updater/box.json
[debug] Moving updater/composer.json
[debug] Moving updater/composer.lock
[debug] Moving updater/CONTRIBUTING.md
[debug] Moving updater/COPYING-AGPL
[debug] Moving updater/index.php
[debug] Moving updater/pub
[debug] Moving updater/src
[debug] Moving updater/vendor
[debug] Moving updater/README.md
[debug] Moving updater/.travis.yml
[debug] Moving updater/.scrutinizer.yml
[info] Execution of upgrade:postUpgradeCleanup command stopped. Exit code is 0
[info] ownCloud 9.1.6.2 found
[debug] Moving updater/.gitignore
[debug] Moving updater/nbproject
[info] ownCloud 10.0.3.3 found
[debug] Replacing CHANGELOG.md
[info] ownCloud 10.0.10.4 found
[info] ownCloud 10.1.1.1 found
the following topic is giving a few things to check. I think these could help here as well:
Thanks very much for this, well done. It looks very similar to my problem.
This solution looks very promising:
I am not sure where to find “the database” however. I presume it’s not owncloud/data/owncloud.db… I will keep looking unless someone can give more specific instructions.
So I concluded that owncloud/data/owncloud.db is indeed the file I need to try and change. I spent the last hour learning how to be dangerous in an sqlite database. It appears the command I need is something like
sqlite3 owncloud.db
sqlite> UPDATE oc_appconfig
…> SET configvalue = ‘no’
…> WHERE appid = ‘drawio’ AND configkey = ‘enabled’;
With thanks going to https://www.tutorialspoint.com/sqlite/sqlite_update_query.htm
and https://stackoverflow.com/questions/4686376/changing-a-value-in-sqlite3
This app helped me work out what was going on within an offline copy of owncloud.db. https://sqlitebrowser.org/
I’ll be back shortly to let you know if this works…
That did the trick. I am very happy with this outcome. The first attempt to update via the web interface front page didn’t work and owncloud put itself back into maintenance mode. I went back to owncloud/config/config.php and changed ‘maintenance’ to => false, then tried again. I’ve now got everything back to how it was apparently. I didn’t need drawio and I’m not sure why I had it so no loss there.
Thanks again Owncloud and especially Tom42
