- Manually installed version of 10.2.1
- Configure read and write permissions on config.php.orig
- Use Upgrader App in Owncloud Interface
- Upgrade completes successfully
- Access login page for Owncloud Web Interface on frontend
- Error message displays (see attached screenshot)
After install is successfully. User should be able to access and see login screen with login fields to login.
An error message displays install. See attached screen shots
- CENTOS 6.10 [dedicated17] * [ v84.0.9]
Linux
MySQL
10.3.0
10.2.1
manual install
https://scloud.shinshuri.com/index.php/settings/admin#security-warning
