Hallo,
i am running a centos7.1 (1503 core) and owncloud 8.1.1-12.1
nowadays we have a stable oc with the version 10.0.10 available.
http://download.owncloud.org/download/repositories/stable/CentOS_7/ce:stable.repo
so the question arises naturally: whats the best practice to upgrade on oc 10.0.10 ?
As far as i have read the instructions, there should be all point releases executed to reach 10.0.10.
Isnt it not better (cleaner ) to install 10.0.10 fresh ?
and besides, centos should also be updated on 7.6.
And are the “remi” php (7.2) packages a safe bet ?
So in short:
should i first update centos and then deal with OC or vice versa ?
and whats the best way to get to 10.0.10 from 8.1 ?
Are there any people outside with the same constellation and some advice ?
Any advice is appreciated…
greetings gunter
