Du könntest das hier versuchen, falls möglich.
    From your description, I assume you don’t have shell access, no option to run the suggested occ app:disable.
This is what I would try in such situation. Without any warranty.
If you have a tool like phpMyAdmin to access the DB, you can use it, to disable all the apps in question.
Go to table oc_appconfig, configkey enabled, set configvalue to No. Repeat for each app in question. Then start over with the upgrade.
Finally you can enable the apps in the admin panel. One by one, to be sure!
                Renate
                    January 8, 2019, 10:21am
                  23
              Hi, there is another topic (how can I link them?) Link  where I was able to find the way out. Thanks for your support, too.
                alfredb
                    January 8, 2019, 11:58am
                  24
              I do not understand this.  Could you repair and finish your update as described in the linked post?
                Renate
                    January 8, 2019,  1:52pm
                  25
              Yes. After some research I was able to connect via Mac terminal and use the occ codes. New territory for me. There were no app installed before, I had do do this first via Marketplace and FTP. Finally the update ran successfully.
