After configuration, the client should work in the background with no further input required.
Every time after logging in, the client asks for the password. This used to happen (almost) every time I would install owncloud on a fresh xubuntu installation, however there used to be a workaround by installing libqtkeychain0. Unfortunately, this package does no longer get maintained, and therefore is not available for install on the 19.10 ubuntu repos anymore.
I have tried activating the Gnome Services in the xfce menu. Also, other programs accessing the keychain work flawlessly (e.g. evolution mail client)
Interestingly, with other desktop environments (I tried Ubuntu Budgie 19.10), this did not occur.
- Install Xubuntu 19.10
- Connect your account
- Log off and on again (or reboot)
Server configuration (I dont think this is a server problem but anyway)
Operating system: Ubuntu Server 18.04
Web server: Apache 2.4.29
Database: MySql 5.7
PHP version: 7.2
ownCloud version: 10.0.3.4
Client version: 2.6
Operating system: Xubuntu 19.10
OS language: English, but with german regionale
Qt version used by client package (Linux only, see also Settings dialog): 5.12.5
Client package (From ownCloud or distro) (Linux only): From Owncloud Repository
Installation path of client: I’m not sure how to check that, but I asume the default path as I installed it via apt without any further parameters
logs.
- Client logfile: Output of
owncloud --logwindoworowncloud --logfile log.txt
(On Windows usingcmd.exe, you might need to firstcdinto the ownCloud directory)
(See also http://doc.owncloud.org/desktop/2.2/troubleshooting.html#client-logfile )
Web server error log:
