Hallo,
I run Onwcloud since several years on my FreeBSD server but recently get the error message via the web client for whatever file location I click: “Zugriff auf den Ordner fehlgeschlagen”
There is no error in the http log
Operating system: FreeBSD
Web server: Apache24
Database: sqlite (small setup with few users)
PHP version: php74
ownCloud version: (see ownCloud admin page) 10.10 stable
Where did you install ownCloud from: tar bundle
"system": {
"datadirectory": "\/usr\/local\/www\/owncloud\/data",
"dbtype": "sqlite3",
"version": "10.10.0.3",
"installed": true,
"instanceid": "507da345ca667",
"maintenance": false,
"forcessl": false,
"loglevel": 2,
"theme": "",
"default_language": "en_GB",
"trusted_domains": [
"www.mydomain.de", <--- changed before comping in here
"192.168.6.96",
"192.168.6.96"
"0": [
"192.168.6.96"
"mail_smtpmode": "smtp",
"mail_smtpport": "465",
"mail_smtpsecure": "ssl",
"mail_smtpauth": 1,
"mail_smtpauthtype": "LOGIN",
"allow_user_to_change_mail_address": ""
**List of activated apps:**
Enabled:
- activity:
- Version: 2.7.0
- Path: /usr/local/www/owncloud/apps/activity
- calendar:
- Version: 1.6.4
- Path: /usr/local/www/owncloud/apps/calendar
- comments:
- Version: 0.3.0
- Path: /usr/local/www/owncloud/apps/comments
- configreport:
- Version: 0.2.1
- Path: /usr/local/www/owncloud/apps/configreport
- contacts:
- Version: 1.5.5
- Path: /usr/local/www/owncloud/apps/contacts
- dav:
- Version: 0.7.0
- Path: /usr/local/www/owncloud/apps/dav
- federatedfilesharing:
- Version: 0.5.0
- Path: /usr/local/www/owncloud/apps/federatedfilesharing
- federation:
- Version: 0.1.0
- Path: /usr/local/www/owncloud/apps/federation
- files:
- Version: 1.5.2
- Path: /usr/local/www/owncloud/apps/files
- files_external:
- Version: 0.9.0
- Path: /usr/local/www/owncloud/apps/files_external
- files_mediaviewer:
- Version: 1.0.5
- Path: /usr/local/www/owncloud/apps/files_mediaviewer
- files_pdfviewer:
- Version: 1.0.1
- Path: /usr/local/www/owncloud/apps/files_pdfviewer
- files_sharing:
- Version: 0.14.0
- Path: /usr/local/www/owncloud/apps/files_sharing
- files_texteditor:
- Version: 2.4.1
- Path: /usr/local/www/owncloud/apps/files_texteditor
- files_trashbin:
- Version: 0.9.1
- Path: /usr/local/www/owncloud/apps/files_trashbin
- files_versions:
- Version: 1.3.0
- Path: /usr/local/www/owncloud/apps/files_versions
- firstrunwizard:
- Version: 1.2.0
- Path: /usr/local/www/owncloud/apps/firstrunwizard
- gallery:
- Version: 16.1.2
- Path: /usr/local/www/owncloud/apps/gallery
- market:
- Version: 0.6.3
- Path: /usr/local/www/owncloud/apps/market
- notifications:
- Version: 0.5.4
- Path: /usr/local/www/owncloud/apps/notifications
- provisioning_api:
- Version: 0.5.0
- Path: /usr/local/www/owncloud/apps/provisioning_api
- systemtags:
- Version: 0.3.0
- Path: /usr/local/www/owncloud/apps/systemtags
- templateeditor:
- Version: 0.4.0
- Path: /usr/local/www/owncloud/apps/templateeditor
- updatenotification:
- Version: 0.2.1
- Path: /usr/local/www/owncloud/apps/updatenotification
No
I have an nginx server running that acts as proxy and forwards to my jail as follows:
location /owncloud {
proxy_pass http://192.168.6.96:80;
proxy_redirect off;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
There are no commands defined in the “ldap” namespace.
Safari
Mac
