502 error with Univention
Hi
I had a problem with my server before the lockdown and I was able to restart it only many days ago.
Since the restart, I had a 502 error when I try to reach owncloud. The message is :
502 bad gateway
The proxy server received an invalid response from an upstream server.
Apache/2.4.25 (Univention) Server at furya.ovh Port 443
My setup is :
  • windows 10 as host
  • workstation
  • ucs 4.4 with owncloud image that I downloaded from owncloud site
I can view the Univention pages. I have this error only when I try to go to /ownlcoud.
Is something possible to restart my owncloud without loosing everything ? Or do I need to reinstall ?
How to not loose calendar stuff ? And how to prevent this error ?
Thank for your help.
Operating system: windows 10 with workstation for the host / Univention Corporate Server 4.4-4 errata617 for the image
Web server: Apache 2.4.25
PHP version: 7.0.33-0+deb9u7
ownCloud version: (see ownCloud admin page) can’t access
Where did you install ownCloud from: ucs 4.4 image
Signing status (ownCloud 9.0 and above): can’t access
The content of config/config.php: I have this error “Could not open input file: occ”
List of activated apps: I have this error “Could not open input file: occ”
Are you using external storage, if yes which one: smb
Are you using encryption: no
Are you using an external user-backend, if yes which one: no one
can you post the docker logs of the ownCloud container?
“docker logs owncloud_owncloud_1” should do the trick.
Hi
Thank for your help !
I don’t use docker. I have a ucs VM inside workstation.
i think that the UCS app for ownCloud is using docker internally.
Hi
I saw something about univention bug here :
https://help.univention.com/t/owncloud-10-2-proxy-error-no-mysql-connection/13241/3
As I don’t have time, I simply reinstal everything.
Hope it can help others !
it seems the problem originates from a defective UCS update if i’m understanding this blog post correctly and the only way is indeed to reinstall (at least the affected apps):
