- using ubuntu 16.04 and installed owncloud from recommended STABLE repository as descriped in download.owncloud.com
- automatic package upgrade occured (i am using cron-apt) for following packages: owncloud owncloud-deps-php7.0 owncloud-files => upgrade from 9.1.5.2 to 10.0.0
- i manually disabled the calendar app (occ spp:disable calendar) to bring upgrade to work (as described in “known bugs”)
- known issue inhibited upgrade (missing databasefield "publicuri" in oc_dav_shares after upgrade to 10.0.0 (stable) from 9.1.5 · Issue #27754 · owncloud/core · GitHub), so i generated the missing databasefield “publicuri”
- activated / updated to new calendar app in webinterface (market)
- all seems to work now, including calendar in webinterface - but not synchronizing with mobile devices using caldav
- calendars in mobile clients (android) should synchronize
1a) for own calendar(s)
1b) for calendar(s) shared from other user
- connection broken => no sync => so i newly created an caldav account with the new address (example.com/owncloud/remote.php/dav), which now works for me, BUT: all users have to change this in their devices => very user-unfriendly
- tried to share a calendar from one user to another (webinterface), but this doesn’t work: after typing in a valid username, the line to checkmark “may change” (“kann bearbeiten”) does not appear.
Operating system: ubuntu 16.04
Web server: Apache/2.4.18 (Ubuntu)
Database: mysql
PHP version: 7.0.15-0ubuntu0.16.04.4
ownCloud version (see ownCloud admin page): 10.0.0.12
Updated from an older ownCloud or fresh install: 9.1.5.2
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): no
ownCloud configuration
Go to the admin page, click on 'admin' -> 'Generate Config Report' -> 'Download ownCloud config report' or use the command line `sudo -u www-data php occ config:list system` (please sanitize sensitive data):
"basic": {
"license key": "",
"date": "Sun, 30 Apr 2017 06:03:26 +0000",
"ownCloud version": "10.0.0.12",
"ownCloud version string": "10.0.0",
"ownCloud edition": "Community",
"server OS": "Linux",
"server OS version": "Linux kudahms.de 4.4.0-042stab120.18 #1 SMP Fri Jan 13 10:32:04 MSK 2017 x86_64",
"server SAPI": "apache2handler",
"webserver version": "Apache\/2.4.18 (Ubuntu)",
"hostname": "kudahms.de",
"user count": 8,
"user directories": 8,
"logged-in user": "uwe"
"config": {
"updatechecker": false,
"instanceid": "ocjm2jb6whjw",
"trusted_domains": [
"kudahms.de",
"v43439.1blu.de"
"overwrite.cli.url": "http:\/\/kudahms.de\/owncloud",
"dbtype": "mysql",
"version": "10.0.0.12",
"dbname": "oc",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"logtimezone": "Europe\/Berlin",
"installed": true,
"overwriteprotocol": "https",
"maintenance": false,
"mail_from_address": "u.dahms",
"mail_smtpmode": "php",
"mail_domain": "arcor.de",
"theme": "",
"loglevel": 3,
"enable_previews": true,
"memcache.local": "\\OC\\Memcache\\APCu"
"integritychecker": {
"passing": true,
"enabled": true,
"result": []
"core": {
"backgroundjobs_mode": "cron",
"installedat": "1475784193.2007",
"lastcron": "1493532001",
"lastupdateResult": "[]",
"lastupdatedat": "1493532146",
"public_files": "files_sharing\/public.php",
"public_webdav": "dav\/appinfo\/v1\/publicwebdav.php",
"repairlegacystoragesdone": "yes",
"shareapi_allow_public_notification": "yes",
"umgmt_send_email": "true",
"umgmt_show_backend": "false",
"umgmt_show_email": "true",
"umgmt_show_last_login": "true",
"umgmt_show_storage_location": "false",
"vendor": ""
<<<clipped>>>
Integrity status for oC9+
paste the results here.
